Old 11-29-2015, 12:01 PM   #1
BrickandBlockGuy
BrickandBlockGuy's Avatar
Default New Front seal
New member here, that needs help. I plan on switching out the robe seal on the front of my 1950 239hp flatty. Got the crank pulley off, but the crankshaft pulley extension with the spirals on it is tight. Does this bushing have a key way or does it just slide off? Any idea's? I plan on installing the new and improved O ring rubber seal with new bushing. Thanks
BrickandBlockGuy is offline   Reply With Quote
Old 11-29-2015, 12:38 PM   #2
Russ/40
Russ/40's Avatar
Default Re: New Front seal
It just slides on and is locked in place by the pulley bolt.
Just my opinion, but can the new seals. The rope works fine and will outlast the rubber seals.
Old 11-29-2015, 06:48 PM   #3
BrickandBlockGuy
Was able to get the oil spiral bushing off crankshaft....After chain vise grips and a hammer did not work....The chisel and hammer worked....was just tight on shaft...Now I will go ahead and use the 2 piece rubber seal with new crankshaft bushing....and lots of silicon sealant.....Thanks
Old 11-29-2015, 07:58 PM   #4
flatjack9
flatjack9's Avatar
Easy on the silicon.
Old 11-29-2015, 08:21 PM   #5
BrickandBlockGuy
a dap will do ya.....
Old 11-30-2015, 09:54 PM   #6
4t8v8
Been using rope seals for 60 years. Finally tried the one piece rubber. Won't do that again. By the way. Go light with the silicone sealer.
4t8v8 is offline   Reply With Quote
