05-19-2010, 11:01 AM | #1 |
Tube type schocks on a 48
I going to install tube type schocks on my 48 Conv. I have a NOS Monroe rear set with brackets, but no instructions. Need help on how they go on. I have the two front upper brackets but don't see how they mount. Do you have to drill holes in frame?? The front axle has holes for bottom stud but I only have 1 stud. Anyplace to buy another?? Thanks for any help.
05-19-2010, 01:00 PM | #2 |
Re: Tube type schocks on a 48
Steve, most of the kits I've seen for those old cars were made to bolt into the existing frame holes used for the friction shocks. If yours for the front are not like that, let me know because I think I have a set that mount in the original holes for the front. But, I never figured out how they mount on the wishbone side.
05-19-2010, 03:30 PM | #3 |
If your 48 is really a 48, and stock, it is supposed to have tube shocks as OEM. There is a series of articles in old V8 Times that covers all this.
'Course, having said that, there are always exceptions to anything 'ford'. What I'm trying to get at, you shouldn't need any kits - original 48 parts are generally available at the swaps ??? |
05-19-2010, 04:29 PM | #4 |
Not all '48's have tube shocks, and some lack the boss and hole in axle, too.
I think all do have the frame holes for the stock setup, and stock rear lower mounts will bolt in. This stuff has suddenly become fairly scarce and pricey, though, and there are more people looking for it for use on A-V8's and such too, people who don't like the look of current streetrod kits. |
05-19-2010, 04:36 PM | #5 |
Let me have your number, I just installed tube shocks on my 48.
05-19-2010, 04:45 PM | #6 |
05-22-2010, 09:38 PM | #7 |
Hi could you tell me where to get the bolts for the upper rear shock mount, startingt to do this to my 48 has the holes in the frame, but the front axle does not have the hole or boss for the lower mount stud there will either drill a hole or make something that will work, i have the frame mounts i belive the Ford ones thanks Laurie
05-23-2010, 04:34 PM | #8 | |
Thanks, Gary [email protected] |
05-24-2010, 11:13 AM | #9 |
Gary i bought mine at Advance Auto Parts. Do not bother to ask for a old Ford shock bolt, they will not know what you are talking about. Ask for a shock mount bolt. I beleive the brand was Dormans and they were around $5 a peice. Marv
05-25-2010, 06:29 PM | #10 | |
