Old 12-21-2021, 09:06 PM   #21
Zeke3
Zeke3's Avatar
Default Re: Replace kingpin & spindle
Anthony, I installed the bushings dry using a bushing driver set and a small ballpeen hammer. The press is not very heavy on them and they drive in easily by hand, just make sure you line up the holes in the bushings with the grease fitting holes in the spindle.
Zeke3 is offline   Reply With Quote
Old 12-22-2021, 12:53 PM   #22
AnthonyG
AnthonyG's Avatar
Thx Zeke3
Nomad
AnthonyG is offline   Reply With Quote
Old 12-23-2021, 09:21 AM   #23
rich b
rich b's Avatar
Originally Posted by AnthonyG View Post
Another question, can I use a large machinists vice to press greased up bushings into spindles? Can’t see with the spindle config it’d be any better in an arbor press.
A good sized hammer along with bushing driver that usually comes with kingpin reamers does a good job of removing the old bushings and installing the new.
While I've been using reamers for fifty odd years; GB's dowel method looks to be a way to do it at home without being dependent on a special tool or the whims of a machine shop.
rich b is offline   Reply With Quote
Old 12-23-2021, 01:09 PM   #24
V8COOPMAN
V8COOPMAN's Avatar
Hereafter, officially referred-to as a "GB Reamer"! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-23-2021, 03:22 PM   #25
tubman
tubman's Avatar
GB has class; I don't. I would have cut the bowl off the spoon as a matter of course and nobody would have cared what I did or not.
Leaving the bowl on the spoon is what legends are made of.
tubman is online now   Reply With Quote
Old 12-23-2021, 03:59 PM   #26
V8COOPMAN
V8COOPMAN's Avatar
Plus, Momma can still stir-up supper. IF Momma uses the drill, supper should be ready PDQ! DD
T5 W/TORQUE TUBE
Old 12-23-2021, 04:01 PM   #27
GB SISSON
GB SISSON's Avatar
Aw shucks guys. It's way more fun swiping the Missus' spoon. It's right up there with washing parts in the dishwasher when she's off visiting here sister.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
