12-21-2021, 09:06 PM | #21 |
Re: Replace kingpin & spindle
Anthony, I installed the bushings dry using a bushing driver set and a small ballpeen hammer. The press is not very heavy on them and they drive in easily by hand, just make sure you line up the holes in the bushings with the grease fitting holes in the spindle.
12-22-2021, 12:53 PM | #22 |
Thx Zeke3
Nomad |
12-23-2021, 09:21 AM | #23 | |
While I've been using reamers for fifty odd years; GB's dowel method looks to be a way to do it at home without being dependent on a special tool or the whims of a machine shop. |
12-23-2021, 01:09 PM | #24 | |
Hereafter, officially referred-to as a "GB Reamer"! DD |
12-23-2021, 03:22 PM | #25 |
GB has class; I don't. I would have cut the bowl off the spoon as a matter of course and nobody would have cared what I did or not.
Leaving the bowl on the spoon is what legends are made of. |
12-23-2021, 03:59 PM | #26 | |
Plus, Momma can still stir-up supper. IF Momma uses the drill, supper should be ready PDQ! DD |
12-23-2021, 04:01 PM | #27 |
Aw shucks guys. It's way more fun swiping the Missus' spoon. It's right up there with washing parts in the dishwasher when she's off visiting here sister.
