Old 08-07-2012, 07:59 PM   #1
OoltewahSpeedShop
OoltewahSpeedShop's Avatar
Default 1946 Ford Tudor - All original- Real Patina
City: Ooltewah
State: Tn.
Price: $7500.00
1946 Ford Tudor sedan with less than 31,000 original miles. Runs and drives perfect. All original body and drivetrain with ZERO rust in the body. The only rust thru anywhere on the car is two small spots in the trunk pan where the old trunk seal leaked (have new seal). Original Henry black paint that has the perfect patina. Original interior that had covers installed probably 50 years ago. Windows all roll up and down great (door glasses have cracks but work perfectly as is), and the cowl vent works as it should.
Holds good oil pressure and runs about 180-190 on my drive to work almost everyday. Transmission shifts smooth as it should with these unbelievably low miles.
Wiring has been upgraded to 12v with all the lights and turn signals working perfectly.
The brakes have been upgraded to power disks on the front with original rears (not sure why, but they work great).
Just like you see it in the pictures, except the rear wheels match the fronts. Tires are like new Coker B.F. Goodrich Silvertown wide white 6.70x15's.
I don't know what else to say, except it's a really great car that I will surely miss when it's gone.
$7500.00
Kevin
423.320.4919...call or text
OoltewahSpeedShop is offline   Reply With Quote
Old 08-26-2012, 03:24 PM   #2
OoltewahSpeedShop
Default Re: 1946 Ford Tudor - All original- Real Patina
Sold...!
