Old 07-04-2013, 06:21 AM   #1
Roadster5040
Roadster5040's Avatar
Default Vacuum plug
Happy 4th anyone know size of threaded plug to put in vacuum hole on manifold I thought it was a threaded 1/8" to large.
Roadster5040 is offline   Reply With Quote
Old 07-04-2013, 06:45 AM   #2
ken ct
Default Re: Vacuum plug
Close but NO brass ring. Its 7/16 X 20 and must be used with a fiber or copper sealing washer. Its the same size as a Stromberg inlet thread. I have the proper fitting but hate to modifiy them for plugging purpouses. ken ct. There too hard to find, ken ct 1-203-360-5945. cell.
ken ct is offline   Reply With Quote
Old 07-04-2013, 08:21 AM   #3
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Wow Ken, the thought did cross my mind but I put the vacuum line in without washers when I installed the correct aluminum manifold on my 36. Sorry about your torture session at rehab yesterday. No pain, no gain!!
dean333 is offline   Reply With Quote
Old 07-04-2013, 08:28 AM   #4
uncle max
uncle max's Avatar
Inlet thread is 7/16-24.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 07-04-2013, 10:18 AM   #5
ken ct
Sorry Max the 1 vacume hole on the later CI intakes is 7/16 x 20. Thought it was same as Strom inlet. Not so i guess it is. Not sure which hole or holes hes talking about ,he mentioned leaving off the washers,there are no washers or ferrels on the vacume holes on a 36 [2],Now i dont know what hes doing????? ken ct.
Old 07-04-2013, 11:59 AM   #6
dean333
dean333's Avatar
If you guys are talking about the inlet on a 36 aluminum intake, which is the same size as the vacuum inlet of the 37-41 distributor, it's DEFINATELY 3/8-24. I just measured it on my 36 intake and the 37-41 distributor I took off.
Old 07-04-2013, 07:10 PM   #7
Roadster5040
It is vacuum line on a 37 for windshield wiper would like to plug permanently. Is this something that can be purchased at hardware store that sells plumbing supplies
Old 07-04-2013, 07:39 PM   #8
dean333
dean333's Avatar
Check a hardware store for a 3/8-24 allen or slotted setscrew. If you can't fine one, I have the fitting you can plug.
Old 07-04-2013, 07:42 PM   #9
ken ct
NO a HW store or Plumbing place will NOT have them. I have both types but im confused by whitch ones you want. ken ct. Roadster5040 call me where getting nowhere!!!!!!!! ken ct, 1-203-260-5945 cell
Old 07-04-2013, 07:47 PM   #10
Roadster5040
Ken I will call you tomorrow thanks all happy 4th.
Old 07-04-2013, 07:55 PM   #11
dean333
dean333's Avatar
Ken, Ace Hardware has quite a selection of setscrews. I thought perhaps a 3/8-24 would be one of them. I wasn't referring to an actual brass fitting. A setscrew would not have to be modified to use as a plug, just screw it in and be done.
Old 07-04-2013, 08:08 PM   #12
dean333
dean333's Avatar
Roadster, I just looked thru an assortment of setscrews I have and found one. If you want it let me know but I'm sure Ace has them.
Old 07-05-2013, 08:07 AM   #13
Robert/Texas
Robert/Texas's Avatar
I have a Mallory distributor on my '34 roadster which I bought from Patricks some 18 or 20 years ago. I just plugged the hole in the original brass fitting with a dab of JB Weld and it still works just fine.
Robert/Texas is offline   Reply With Quote
Old 07-05-2013, 04:34 PM   #14
ken ct
Yea,Dean is probebly right,i didn't think of allen set screws. ken ct. put somr lite lock-tite on the threads for sealent, ken ct, no silicone or teflon tape please.
Old 07-06-2013, 07:20 AM   #15
Roadster5040
Guys I went to ace yesterday and Allen set screw did the trick 3/8-24. Thank you again for all your help. The help from this site is best perk.
Old 07-06-2013, 08:13 AM   #16
dean333
dean333's Avatar
My first direct success story! Thanks
Tim
Old 07-06-2013, 10:25 AM   #17
ken ct
I'll have to go to an ACE store and get a dozen or so as i myself need one occationally. Ive been making them out of old fittings filled up with solder to seal them.Thank you for the tip. Good idea. ken ct.
