Old 07-20-2017, 09:03 PM   #41
barnstuf
Default Re: Starving for gas at highway speed
A friend purchased one of the new Zenith carburetors that have been on the market for quite a few years, and up to 45 mph everything was fine, over 45 he experienced hesitation and starving for gas. He tried to find the problem without result and turned the carburetor over to a professional Zenith restorer. After serious testing he found the secondary well side opening was a tiny bit too small so he enlarged it to proper specs and the problem was solved.
barnstuf is offline   Reply With Quote
Old 04-14-2021, 04:50 PM   #42
kinggrr
Chris - I was reading through this 4-year-old thread of your problem with cutting out above 40mph or so. I was saddened to see the thread end with no solution as I am having same issue. I have rebuilt carb, new ignition, checked fuel, etc, etc. Did you ever resolve yours? Thx...
kinggrr is offline   Reply With Quote
Old 04-14-2021, 05:37 PM   #43
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
King, if you put a new fuel line on check that you don’t have more than 1/8 inch of tubing beyond the ferrule. Common problem. Good luck.
Jacksonlll is offline   Reply With Quote
Old 04-14-2021, 08:51 PM   #44
nkaminar
nkaminar's Avatar
Sounds like a carburetor problem. Try a different one and if that works take the old carburetor apart to check for good flow through the float valve, the correct float level, correct jets with no clogs, jets tight in their threads, vacuum leaks at throttle arm or flange, etc.
Old 04-14-2021, 08:53 PM   #45
nkaminar
nkaminar's Avatar
By the way, the water will be yellow because of the rust it has picked up and the gasoline will look clear with the small volume. Keep emptying the water out of the sediment bowl.
Old 04-14-2021, 10:42 PM   #46
CWPASADENA
CWPASADENA's Avatar
several years ago, there were some poor quality carburetor float valves made with a very small hole for the fuel to pass thru. The car would run fine around town but get it on the highway and it would starve for fuel. When this would happen if you would let up on it for a little while it would get enough fuel to run for just a little more and then start starving again. I ran into this on a Model A of one of our club members. Took the carb apart and found a float valve with a very small hole in it. Replaced the valve, car then ran just fine.
If you have a good steady stream of fuel with the fuel line removed from the carburetor, you may want to check the float valve.
My experience, Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-14-2021, 10:57 PM   #47
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Do you know the office size on the float valve? I’ve seen the spec somewhere, but sure where.
Old 04-15-2021, 10:14 AM   #48
Patrick L.
Patrick L.'s Avatar
Since he hasn't answered must be he got disgusted and sold the monster !
I still think he just had a gas cap issue.
Old 04-15-2021, 10:42 PM   #49
CWPASADENA
CWPASADENA's Avatar
I am not at my shop where I could measure an original and off the top of my head, I do not know the size of the opening in the float valve but if you take it out and look at it, it is obvious that it is a very small hole.
I know Brattons has good valves and I am sure other of the parts suppliers also do. I would not recommend Mac's as most of their stuff comes from China.
Chris W.
Old 04-15-2021, 11:48 PM   #50
redmodelt
redmodelt's Avatar
Probably not as he was online here today around 9:30 Pm.
Old 04-16-2021, 07:49 AM   #51
jimTN
Just fixed a similar problem with my 28. Ordered a pencil filter for the tank and when I drained the gas and pulled the tank valve, found that valve was only about 1/3 open when turned to open. Removed the valve core and drilled the passageways out larger, ground and amount of the lever stop arm and put a metal ship in the lever opening to tighten it up. Problem solved!
jimTN is offline   Reply With Quote
Old 04-16-2021, 11:06 AM   #52
Patrick L.
Patrick L.'s Avatar
That was said ' tongue in cheek ' since he didn't bother to let us know what he found.
