03-01-2013, 05:44 PM | #1 |
how to polish brass
Any home remedies for brass polish?
also... what to do and what NOT to do. thanks guys |
03-01-2013, 05:53 PM | #2 |
Re: how to polish brass
use BRASSO as directerd.....
03-01-2013, 10:05 PM | #3 |
I have also used Brasso with amazing results and very little effort !
Al |
03-02-2013, 11:40 AM | #4 |
Brasso is a good polish, but it starts tarnishing as soon as you finish polishing.
I have not used it in many years, maybe the new version is better?????? I find that "Mothers" polish does a good job and leaves a coating that stops tarnish for some months. "Mothers" polish is available in a lot of auto parts stores. If you have some very heavy tarnish, some very fine steel wool can be helpful, but do not use a coarse steel wool as it will do a lot of scratches on the brass. A tooth brush can be helpful to remove the excess polish out of the joints and cracks. |
03-02-2013, 01:48 PM | #5 |
Brasso does work well but it is abrasive. It has been often used as a final rubbing compound on really fine paint jobs. It will eventually destroy the fine details of the object.
The only cleaner considered safe on brass by most conservation institutes is Nevr-dull. It works well but is a little labour intensive. It does leave an oil like film on the brass that helps slow tarnishing.
Jack Innes, Brooklin, Ontario |
03-02-2013, 02:48 PM | #6 |
We use Flitz Metal Polish, no abrasive, and it leaves a protective coating. Many street Roders use it. I for got to say, never use anything made out of wood as a polishing cloth, even on your Glasses. Always use 100% cotton!, like old clean T-Shirts. Last edited by Kohnke Rebabbitting; 03-02-2013 at 04:05 PM. |
03-02-2013, 06:13 PM | #7 |
Use the Brasso to kill the weeds... Nev-R-Dull is the best by far. I wish they sold the compound for it for a slow wheel. I use it exclusivelly on boat stuff especially chromed brass thats' leached through and turned green. +++++ <-- thats 5 stars! ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" |
03-02-2013, 11:18 PM | #8 |
If money is no object you could gold plate it and it would stay shiny longer. Not that many people can afford gold nowdays.
Wood? or wool?
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
03-03-2013, 05:34 AM | #9 |
Gotta love ol' Herm, but he types with two 4 pound hammers! Great guy tho... glad to see you here Herm instead of that other place where they beat you up all the time! ws
03-03-2013, 09:01 AM | #10 |
Flitz is another good polish but it is slightly abrasive. Probably not enough to cause brass deterioration for a long time but it is thought that it can be harmful in cleaning gun bores & items that cannot afford to be eroded. In the museum conservation field it is considered abrasive. The abrasive in Flitz is Aluminum Oxide, the same stuff used to make sand paper.
Here is an official statement on Flitz from the president of the company to a gunsmith; "" The gentleman that stated "if it is a polish, it has to be abrasive" is right in a very literal sense. However, you are also right about the Flitz, because our polish falls 12% below the government standard for abrasiveness. In other words, the polishing granules are so fine that Flitz can be considered non-abrasive. We can safely claim that because, as you can feel just by putting it between your fingers, it is very smooth. Flitz can be used on even the softest precious metals without scratching. (Of course, a person would have to consider the applicator cloth and make sure they are using a clean, high-quality, soft cloth to apply the polish and for buffing.)""
03-03-2013, 10:01 AM | #11 |
I've used for brass, (that has already been high speed wheel buffed to a bright surface) both Nev-R-Dull and Mothers. They can work, but by far the best for keeping the bright surface shiny and tarnish free is Cape Cod. This polish is in little cloth pads, making it easy to use. Darn good on brass!
Learned about Cape Cod from a T'er who has a mulitiple best in class blue ribbon T. http://www.capecodpolish.com/product...9418fl3ve2p201 |
03-03-2013, 10:09 AM | #12 |
Forgot to add the advertisement photo, holding up the can of Cape Cod brass wipes like Vanna White.
03-03-2013, 11:06 PM | #13 |
Used lotsa Brasso while doing 4 years in the Army, and found it produced a highly polished brass, in short order, however it does scratch, and close observation reveals same. Everyone used it, so I'm guessing that the Army got it "on the cheap"
Presently using Wenol to restore the sidelights & taillight on my 14 Touring. I'm applying it with a nylon brush in a dremel, and the tarnish (probably 80+ years worth) combines with the Wenol, and dries on. This can be removed with a damp cloth and elbo grease. Final polish application is done with a cloth applicator. Excellent results ! |
03-05-2013, 05:44 PM | #14 |
After applying Mothers/Wenol/Nev-R-Dull/etc. and rubbing it off, consider using Talcum powder poured into an old sock and rubbed onto the cleaned surface. The powder absorbs the black residue and will make the polished brass surface brighter. I have been instructed by my plater (who told me of this powder method) that compounds and polishes have greases which hold the cleaners into solution, and the black is the after-effect of the greases. He claims the grease absorb dirt and cause scratches & dulling. Maybe the grease protects from oxidation???
03-05-2013, 10:25 PM | #15 |
Happich Simichrome
03-06-2013, 09:37 PM | #16 |
Tomato Ketchup in a plastic bag for 24 hours, followed by light polishing worked for me. Cleaned up the 1912-1916 radiator on the Rajo T after it had been dipped and tested.
11-15-2013, 09:12 PM | #17 |
Lots of great info here. I have a brass radiator cover, steering column and steering gear box that haven't been touched since the early 60's so I'm wondering if any of the above would cut through the tarnish that is there? I was thinking of a buffing wheel and buffing paste but if I could start with Brasso and end with one of the other products I would be glad to give that a try too.
11-18-2013, 03:22 PM | #18 |
I for one like the look of old brass patina. I polished a brass phonograph horn and every imperfection leaped out at me. 25 years later lookin good again.
A personal preference to be sure, that and I'm lazy.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
11-18-2013, 04:39 PM | #19 |
Horseless Carriage Club did a test of over 50 polish types a few years back. The best was Winchester Arms Brass Polish and if I remember right, Mothers was rated 2or 3. You might be able to find this article at HCCA.org.
