Old 05-12-2020, 05:08 PM   #1
DBSHELTON
Default Carb Tester
I want to build a carb float level bench tester. Do any of y'all have one you could post pictures?
DBSHELTON is offline   Reply With Quote
Old 05-12-2020, 05:27 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Carb Tester
See page 12 of this excellent write-up by Tom Endy:
https://www.brattons.com/media/wysiw..._-_11-2007.pdf
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 05-12-2020, 06:01 PM   #3
burner31
burner31's Avatar
Good article Jim, thanks for sharing
Think I'll try that float level tester on my Tilly
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-13-2020, 09:03 AM   #4
stevemclark
stevemclark's Avatar
Try this,screws in the bottom of the float bowl on the car .https://www.mikes-afordable.com/product/A9599.html..
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 05-13-2020, 09:15 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
That won't really work for flowing jets.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-13-2020, 10:44 AM   #6
History
History's Avatar
I used a glass jar. Someone just did that and posted a photos of it zip tied to the jar.
History is offline   Reply With Quote
Old 05-14-2020, 11:05 AM   #7
garyjohn
There is an article in the May/June 2019 MAFCA Restorer on page 12-13 on how to build a test stand. Leaves some info out and is not too good, but a place to start.
garyjohn is offline   Reply With Quote
Old 05-14-2020, 09:06 PM   #8
Conaway2
Conaway2's Avatar
I used this tester this afternoon to set the fuel level in my Zenith-2 carb. It works well and is easy to use. I discovered I had the float set way too low - I had 3 washers under float valve - removed 2 of them, and the fuel level was perfect.
Jim
Conaway2 is offline   Reply With Quote
Old 05-15-2020, 11:10 AM   #9
30 Closed Cab PU
Jim
With one shim - was the float solder line level, angled down, or angled up when upper carb/float is upside down, when compared to the upper half of the carb?
Think I read somewhere it should be level.
30 Closed Cab PU is offline   Reply With Quote
