Old 01-20-2020, 01:05 AM   #1
cajunfirehawk
cajunfirehawk's Avatar
Exclamation stromberg 97 metal fatigue?
Don't you hate when this happens?? AND I was trying to get the hose nipple OUT, not tighten it...
Plus, All of the used parts I can find for sale to replace this are almost $100!
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 01-20-2020, 03:52 AM   #2
Brian
Brian's Avatar
Default Re: stromberg 97 metal fatigue?
Ouch!! looks like it's been epoxied up previously?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-20-2020, 04:58 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Yep, it sure looks like someone who thought that JB weld was the perfect solution for a broken part, put a layer of it inside to fix it. (guess that didn't pan out to be a permanent solution)
Old 01-20-2020, 05:34 AM   #4
Mart
Mart's Avatar
Ooyah!
I've always been a 94 guy, they seem easier to find here. Never had a 97. I hope you can find a decent used part to repair it.
Mart.
Old 01-20-2020, 08:02 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
What is worse is that somebody trusted JB Weld or something similar to not only fix the prior problem, but to also NOT LEAK and potentially cause a fire.
Now this is going to sound bad, but it is actually a good thing that it snapped off - as it prevents the carb from being used "as is" . . . now it will be fixed - with a new carb center as it should have the first go round.
Just put a "Want Add" in for a new center section - you might find one for less than a complete carb core.
Best of luck!
B&S
Old 01-20-2020, 08:12 AM   #6
mfirth
Charlie NY maybe. He' a 94 guy, but might have a 97 on the shelf. GR8 to deal with too!
mfirth is offline   Reply With Quote
Old 01-20-2020, 09:24 AM   #7
Charlie ny
caj,
E mail me at [email protected] , I've got 97 bowls up the ying yang.
If you wish one will be heading your way pronto.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 01-20-2020, 10:58 AM   #8
cajunfirehawk
Yep. I figured it was a patch job, Thanks Charlie, email sent buddy!
Regards,
Todd
Old 01-20-2020, 01:49 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Charlie ny View Post
……….got 97 bowls up the ying yang!
That Charlie's funny, yeah? That Charlie is good, YEAH ! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-20-2020, 02:37 PM   #10
scicala
scicala's Avatar
JB Weld is good for certain things, but that could cause your car to burn to the ground.
I've seen it work when exposed to gasoline before ethanol was added years ago. I've seen carbs using fuel with 10% ethanol, where the JB Weld starts to deteriorate.
Sal
Sal
Old 01-24-2020, 12:59 AM   #11
dumb person
dumb person's Avatar
Is it bad that i figure, in a pinch, you could drill tiny holes either side & bond it slightly with solder?
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 01-24-2020, 12:16 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
Lightbulb Re: stromberg 97 metal fatigue?
caj,
Charlie ny
That Charlie ny is just an all around good guy!!
John
Old 01-24-2020, 12:29 PM   #13
RalphM
RalphM's Avatar
I have a 97 with an extra 3-16” hole drilled in the top of the bowl. Was thinking JB weld to fill it, but now I’m thinking I should tap it for a plug.
RalphM is offline   Reply With Quote
Old 01-24-2020, 12:37 PM   #14
cajunfirehawk
Thumbs up Re: stromberg 97 metal fatigue?
Indeed, already have a replacement tank in route thanks to Charlie!
Regards,
Todd
