05-18-2017, 04:50 PM | #1 |
Sea-foam, MMO, or fogging to help sticky valves?
Last fall I purchased a 28 Phaeton which has not been driven in a long time, it seems to have the problem of backfiring and bucking that I would atribute to sticky valves.
My question is whether MMO in the gas, sea-foam, or "fogging" the engine with penetrating oil will help this issue. I hate to tear into the engine when the weather is finally cooperative for driving it. Any thoughts? |
05-18-2017, 05:20 PM | #2 |
Re: Sea-foam, MMO, or fogging to help sticky valves?
I would put a can of Sea Foam in the oil, and another can in the gas. After running the tank of gas out, just keep adding 4 ounces of MMO to each 10 gallons of gas.
05-18-2017, 06:40 PM | #3 |
Tom's advice is roughly the same as I would give. Except, I would stress running it more, even if it was only a fast idle in the driveway. I almost for got, I had a wheel Horse with something wrong with the engine, it would rev up beyond say 600 rpm (Hadn't run in a while either) I decided to cut the grass anyway (But slowly) I used Sea Foam and MMO at greater than the recommended portions. ( I measure in Glugs) Whaddya know? it must have cleared itself it suddenly started running better than it had in a long time. I'm pretty sure it was it the Carb. and I had it apart twice and still it wouldn't run right until it was in the mood.
Terry Last edited by Terry, NJ; 05-18-2017 at 06:51 PM. |
05-18-2017, 06:53 PM | #4 |
Did what Tom recommended for our Flathead about three years ago was having a stuck valve issue.
Worked like a charm wouldn't go w/o SeaFoam and some MMO in my gasoline today for the old cars. |
05-18-2017, 06:53 PM | #5 |
I do the "glugs" also, no problems. MMO, SeaFoam or Stabil. Won't hurt anything.
Paul in CT |
05-19-2017, 12:44 AM | #6 |
Yes
05-19-2017, 01:33 AM | #7 |
Pull the plugs and squirt some penetrating oil at the open valves.
05-19-2017, 07:23 AM | #8 |
Thank you guys, I was afraid that this thread would wind up as another Pandora's box issue...
I pulled the plugs and did what Updraught suggested, but I think she needed a little more than that. Black flies are out in Maine, so a little more smoke from the car can't hurt and we are still in that courting stage where I'm going larger runs each time out until I get confident with the ol' gals reliability. At some point you have been there too I would assume. |
05-19-2017, 09:57 AM | #9 |
I can appreciate you doing only one thing at a time. Seafoam in engine oil, mmo in gas tank, and go for a long drive! And drive it like you stole it, rev the motor, don't baby it !
If you don't want to get to far from home, drive in circles :-) |
05-19-2017, 03:08 PM | #10 |
MMO in the fuel is my cure for sticky valves (usually in engines sitting for many months). Back in the '80s I worked as a mechanic and we would install MMO oilers that fed MMO into the intake manifolds of the trucks and other equipment from the local steel mill (lots of idle time and many ran on LPG). Never had any problems.
1929 (early) Model A Special Coupe - restored to original 1964 Buick Wildcat convertible |
05-19-2017, 03:14 PM | #11 |
05-19-2017, 03:45 PM | #12 |
I agree with the above, but it could also be a condenser or loose electrical connection.
05-19-2017, 04:04 PM | #13 |
05-19-2017, 05:57 PM | #14 | |
Might need to let the stuff soak for several days, or as others have said, it could be something else. |
05-19-2017, 06:56 PM | #15 | |
Have you done a compression or leak down test? Valves hanging open would clearly show.
All steel from pedal to wheel |
05-19-2017, 08:27 PM | #16 |
I'd rather fight than Switch .... Kerosene for me for past 60 years to dissolve varnish on valve stems and in valve guides; worked for my Dad and grandpa since 1912 .... pour in all (4) spark plug holes and allow valve stems to soak 24 hours overnight ...... 100% cure .... 100% of the time.
On start up, your Black Flies won't even be thinking about courting ..... with Kerosene smoke ...... they will probably be headed straight for North Korea. Last edited by H. L. Chauvin; 05-19-2017 at 08:31 PM. Reason: typo |
06-13-2018, 05:53 PM | #17 | |
Thanks |
06-13-2018, 07:08 PM | #18 | |
if deffinately cannot hurt to run seafoam or MMO in either oil or gas and should be done anyways. Seafoam can be added anytime to the crankcase but the reccomend 100-300 miles before changing oil and filter. Seafoam will remove all sorts of gunk and without an oil filter it may gunk and overload the oil so watch the color closely. if it starts turning black quick, dump it and dump in the cheapest multiweight oil you can find (walmarts supertech oil is pretty decent and cheap like $12/5qt jug cheap) and add the seafoam again and run it watching the color closely.
1929 Model AA - Need long splash aprons! |
06-13-2018, 07:17 PM | #19 |
Granpa used coal oil cause it was handy and proven. Dad learned from him, but I bet if a gallon of Kerosene and a jug of MMO or Sea foam was sitting on the bench, if he grabs the Kerosene I would guess he was stubborn! Tell us the Compression.
06-13-2018, 07:57 PM | #20 |
It's a really cheap diagnostic to connect a vacuum gauge, and they can help figure out a lot of issues. Old school aid that works well. Lot's of places online to help you learn how to interpret what you see on the gauge. Really just basic diagnosis 101.
Corley ----------------- Subscribed to the KISS principle! |
Thread Tools | |
Display Modes | |
