10-30-2016, 09:13 AM | #1 |
Model A rims
Hi Gents,
One of my rims do not bolt up against the drum as I understand they should. The centre section bolts up, but the outer rim of the wheel hub has about a quarter inch gap from the drum. These are 21 inch rims and they seem to have the same centre section, although this one seems to have a thinner outer edge, hence the gap. Any suggestions will be much appreciated.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
10-30-2016, 09:27 AM | #2 |
Re: Model A rims
You probably have an early 28 wheel they were narrower than the later ones because there was no emergency brake on the rear wheels. I have to say you live in a beautiful part of the country I enjoyed visiting Cape Town a few years ago.
10-30-2016, 09:46 AM | #3 |
Re: Model A rims
That rim should not be used on a drum designed to include an emergency brake. There is not the support required with that combination.
10-30-2016, 01:39 PM | #4 |
Re: Model A rims
as the others said- use it for your spare...............!
10-30-2016, 02:26 PM | #5 |
Re: Model A rims
Thanks Gents,
You help is much appreciated. I'll use it as a spare as suggested. Hi John, Yes, we are blessed to live in such a beautiful part of the world. Pity I missed you on your last visit, maybe next time.
10-31-2016, 08:30 AM | #6 |
Re: Model A rims
10-31-2016, 08:35 AM | #7 |
Re: Model A rims
I would not use it as a spare.
Instead get another car to match the rim.
Dave / Lincoln Nebraska |
10-31-2016, 09:02 AM | #8 | |
Re: Model A rims
Bill W.
