Old 04-27-2016, 03:39 PM   #1
Floats
Floats's Avatar
Default Rear brake levers
Hi Guys,
Can anyone please assist. The rear-brake levers on my RPU are installed with the offset inboard, facing towards each other and the pumpkin. Is this correct or should the offset be outboard, facing to the hubs?
My problem is with them facing each other, the shocks hit on the brake rods. If I turn them around the brake lever might interfere with the emergency brake levers.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 04-27-2016, 04:42 PM   #2
Barber31
Barber31's Avatar
Default Re: Rear brake levers
I have a 31 Tudor and mine are facing outboard or on the backing plate side. They did not interfere with the emergency rods when I had them assembled.
Barber31 is offline   Reply With Quote
Old 04-27-2016, 04:46 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
As Barber 31 said, they face outward, toward the backing plate, but you may have to also swap sides because they angle to follow the frame taper.
Old 04-27-2016, 05:51 PM   #4
Mitch//pa
This is the R/R
Old 04-27-2016, 11:08 PM   #5
Floats
Floats's Avatar
Thank you Gents,
They worked fine until I fitted the shocks. Unfortunately, every speed bump caused the shocks to bump down and put a kink in the rods. Slowly but surely the rear brakes got 'better and better' as the rods got shorter and shorter.
Much appreciated guys and thanks for the photo, Mitch
Regards
Chris
Cape Town
