Old 07-23-2015, 06:24 AM   #1
Mark W.
Mark W.'s Avatar
Default Generator adjustment dumb question
I understand from my service book on HOW to adjust the third brush - but here is the dumb question - exactly where do I hook up the terminals from a multi-meter to read the amperage??? +/- at the battery itself or any ground to the generator cut-out???
Electricity is just not my thing...
Thanks
Mark W. is offline   Reply With Quote
Old 07-23-2015, 06:42 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Generator adjustment dumb question
Amperage, you need to put the meter in line with the wire. That is from the cutout, to the meter, through the meter out to the wire you removed from the cutout.
May I ask why you want to read amps?
Old 07-23-2015, 06:56 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the wire from the output side of the cutout and connect the negative meter lead to the cutout and the positive meter lead to the wire just removed. Start the engine and run it at fast idle, then adjust the third brush for the amps you want.
My original ammeter in the instrument panel is accurate, so I just look at it.
Old 07-23-2015, 09:09 AM   #4
Patrick L.
Patrick L.'s Avatar
That would be my answer, just use the gauge in the vehicle.
Old 07-23-2015, 11:14 AM   #5
Mark W.
Mark W.'s Avatar
Thanks guys - I don't know whether or not I can trust the dash meter yet, so I want to adjust with the new meter, then see if it is any good. I'm just getting down to the nitty-gritty of an engine rebuild from an original car and figured I might as well put on the shiny new generator now the "patina" is lost on the rest of my engine.
Old 07-23-2015, 11:29 AM   #6
Mitch//pa
i always use an external meter for adjustments also..
Old 07-23-2015, 12:50 PM   #7
burner31
burner31's Avatar
There are no "dumb questions" dumb answers yes, but not questions.
Your question was something I needed to know also, so we both got educated, good question.
Thanks
I once told my friend there are no dumb questions, he said "Oh ya, watch this:
Say you're traveling North across the desert at 90mph, do you A: bring your lunch or B: take the bus...true or false?
I replied...no more beer for you fella!
(True story)
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 07-23-2015, 12:59 PM   #8
pooch
pooch's Avatar
Just be careful, the el cheapo multimeters are usually only rated for 10 amps.
And you have to change the positive lead to the other input hole on the meter to read amps.
pooch is offline   Reply With Quote
Old 07-23-2015, 01:19 PM   #9
burner31
burner31's Avatar
Pooch:
How do you get your avatar to move?
I have one I can't use, been trying.
Keith
Shawnee OK
'31 SW 160-B
