Old 10-31-2013, 03:12 PM   #21
G.M.
Default Re: Crankcase Solution wanted!!!
Hary A lot of oil leaks in the rear are from over filling with to much oil. This oil drips from the cotter pin in the pan below the flywheel. You want to tighten the rivets or replace them and the gasket on the dip stick boss this is another place they leak. Good luck with your latest project. G.M.
www.fordcollector.com
