12-20-2021, 09:52 PM | #1 |
1935-37 LED Headlights
Any firsthand experience with the LED headlight retrofit kits being offered?
I think it is Vintique who offers a complete kit with reflectors. Thanks!
Tim Downtown, Ca |
12-21-2021, 12:09 AM | #2 |
Re: 1935-37 LED Headlights
Do yourself a HUGE favor and type-in that "Vin...." name under the "SEARCH" function up in the BLACK band at the top of every page here on FordBarn, and sit back and be amazed at the number of UN-HAPPY customers buying ANYTHING suplied by that name brand. I wouldn't recommend any of that stuff to my worst enemy. DD |
12-21-2021, 07:17 AM | #3 |
I have never dealt with Vintique in Campbell, CA but there is a web site called Rodtiques LLC in Hanover, MA that sells LED Headlight Reflectors. I think they list for around $230 a pair. I also have never dealt with them, just browsing when I came across their web site looking for LED headlights for my 34.
HORSEPOWER is how fast you hit the wall......TORQUE is how far you take the wall with you! |
12-21-2021, 12:28 PM | #4 | |
12-21-2021, 01:15 PM | #5 |
Here's what I found, I already had halogen (no relay) dim at idle, ok at speed. While searching for relay kit on ebay, bumped into a LED conversion. Bought both. I don't remember the brand, but turns out they had the same reflectors, same pigtails. Installed LED and never looked back, just re-aimed those bright headlights.
12-21-2021, 01:32 PM | #6 |
12-21-2021, 03:18 PM | #7 |
Well, here's what WE found, FWIW. Rewiring this little '37 Coupe from scratch recently, 6v, STOCK STOCK. I bought this coupe 20+ years ago, stock as could be, really nice un-restored condition. Well, I let it sit all this time and recently decided to sell-out all my junk for health reasons. My best bud did all of this work to get the car running, safe and reliable for his brother in NW Ohio who bought the car. So, my bud got the car running and stopping well again (stock cable brakes). With that, he completely rewired the car using all reproduction wiring harnesses. As found, none of the lights were even wired-up. The passenger side headlight reflector was some sort of reproduction....didn't even have the hole for the park light socket. I found two solid, yet tarnished-looking reflectors on eBay for $20. They ended-up polishing-up very nicely. Note in the first picture the black Yuckelberries all around the big hole for the bulb and socket. I'm gonna assume that is possibly some carbon from arcing of a loose bulb and socket over the years. More importantly, THAT IS YOUR GROUND surface. Long story short, that was all easily cleaned-up, and a ground wire soldered to each of a pair of NICE, stock bulb sockets from a '39. Think about that GROUNDING situation ...bulb/socket assembly grounds to reflector. Reflector grounds to bucket. Bucket grounds to fender. Fender grounds to body, and grill assy at front, which all eventually grounds to chassis. We ran the soldered ground wire down with the stock harness to a point where each side's ground wire could be grounded through an empty, stock hole in the chassis on each side. Third picture tells the story on that. One thing to remember on '37-ish headlights is that those flutes in the glass headlight cover are there to aim a stock bulb mounted at a pre-determined distance from the glass. That distance may be compromised when using different type bulbs mounted in different reflectors. In other words, you may have a bright light...aiming toward your bumper. DD |
12-21-2021, 03:53 PM | #8 |
Thanks 34p-
I tried to word my question so as not to solicit to many rabbit trails. Agreed DD, most folks overlook the grounding issues......good point on the bulbs, the later developed bulbs are suppose to have the correct bulb placement. Hope to hear more firsthand testimony. I’m starting from scratch & wired for 12v. If someone has a pair of usable original reflectors for $20 drop me a line. The last original pair I bought and had re chromed was over $100. I do not have reflectors so I’m at a decision point. Thanks!
Tim Downtown, Ca |
12-21-2021, 04:13 PM | #9 | |
https://www.ebay.com/itm/15383795733...EAAOSwWSVeTL4C |
12-21-2021, 09:25 PM | #10 |
The restored reflectors are on my Tudor, working like a champ.
I think the 37-8 pass are different. 35-6 pass and 35-7 pickup are the same and have little tabs to hold the 3 spring clips. I’ll give you a call if I find a pair, the last ones I tried to clean didn’t turn out well☹️
Tim Downtown, Ca Last edited by CA Victoria; 12-21-2021 at 09:31 PM. |
12-21-2021, 10:28 PM | #11 | |
And Vintique parts are normally shite in my experience.
12-21-2021, 11:40 PM | #12 |
I have a '38 Deluxe that came to me with a B Drake halogen 12v kit installed. The are not overly bright, but they do aim adequately on high and low beam. I've read of others who have another brand who are not satisfied, and of other Drake kit users who are satisfied. You just have to go with the best info you can get.
