09-28-2018, 01:48 PM | #1 |
Bendix brakes
I have recieved my Bendix brake conversion kit for my 40 Ford, and have painted and assembled it. When I am done going to car shows, I will start the conversion.
09-28-2018, 01:52 PM | #2 |
Re: Bendix brakes
That looks nice, is that the Bob Drake kit?
09-28-2018, 03:50 PM | #3 |
Re: Bendix brakes
What's going on the rear.
09-28-2018, 04:29 PM | #4 |
Re: Bendix brakes
The LOCKHEED-type Ford hydraulics will work just fine in the rear with those shiney, new front brakes. DD
09-28-2018, 05:04 PM | #5 |
Re: Bendix brakes
I got them from cornhusker hot rod parts.
09-28-2018, 05:04 PM | #6 |
Re: Bendix brakes
09-28-2018, 06:26 PM | #7 |
Re: Bendix brakes
I'm still holding out for FlatHeadTed's Bendix conversion kit for Lockheeds before changing anything. Jack E/NJ
09-29-2018, 04:07 AM | #8 |
Re: Bendix brakes
Getting close
09-29-2018, 11:17 AM | #9 |
Re: Bendix brakes
I didn’t know you were working on a conversion Ted. Any hints, or still in design phase?
09-29-2018, 12:07 PM | #10 |
Re: Bendix brakes
That's a great series of pictures of you with your '40 on your website. Keep us posted on how the Bendix installation goes. I'd like to do the same on the fronts of my Fordor.
09-29-2018, 12:28 PM | #11 |
Re: Bendix brakes
Hi Ted: as long as we all know that you are reafing these posts regarding the brakes and your up grades, could you possibly share with us some of the information and a picture or three of what those modifications might look like when installed on a backing plate? There are a lot of us impatiently waiting to view your efforts....😀
09-29-2018, 02:51 PM | #12 |
Re: Bendix brakes
That’s what we want to hear Ted, getting close and right here in NZ. Bring it on.
09-29-2018, 04:44 PM | #13 |
Re: Bendix brakes
Just curious. Did you adjust the anchor pins with drums on prior to painting. If not you may have brakes that are not satisfactory. You may need to touch up the paint at the anchor pins after this procedure.
Ignorance of the laws of physics does not mean they do not apply to you. |
09-29-2018, 06:04 PM | #14 |
Re: Bendix brakes
What anchor pins are you referring to? the large anchor at the top? Instructions say to leave it loose until the drum is on and the brakes adjusted tight, then tighten the nut and loosen the adjuster. There is only a very small adjustment on that top pin, so I am not concerned about a paint chip. It is not a concours car.
09-30-2018, 10:02 AM | #15 | |
Re: Bendix brakes
09-30-2018, 12:54 PM | #16 |
Re: Bendix brakes
"only a very small adjustment"
As small as it seems; it can have a big impact on brake performance. |
10-01-2018, 09:37 PM | #17 | |
Re: Bendix brakes
Cannot say much yet , just a bit more testing
Ted Quote:
11-08-2018, 02:49 AM | #18 |
Re: Bendix brakes
Any updates yet Ted on the brakes?
11-12-2018, 04:56 AM | #19 |
Re: Bendix brakes
Hi all, I plan on updating the brakes on my 37 this winter. Presently lockheeds. My plan was to go with the bendix setup. I'm curious if the bendix in the front and lockheeds in rear are a better way to go, or personal preference. I'm using the wide 5 drums. Thanks Ray
11-12-2018, 08:37 AM | #20 | |
Re: Bendix brakes
Ray.....Keep in mind that it's hard to improve on 100% of anything, and properly-functioning Lockheed brakes ON THE REAR of the car are completely capable of locking-up the tires upon application. Placed on the REAR of any car, the dynamics of braking function is much different than the percentage of the load that FRONT brakes must endure. When you hit the brake pedal, weight on the wheels and tires transfers toward the front of the vehicle. The rear brakes then need only to produce much less in the way of force required to resist tire/wheel rotation. In other words, the rears are essentially capable of handling their percentage of the load, but the fronts (Lockheed) are over-taxed at best. The "mixed" combo works quite adequately. DD |
