02-28-2015, 11:20 PM | #1 |
1930 rims
does anyone know if you can replace some of the spokes in a model a rim by cutting out old wire and welding in new wire. Thanks
03-01-2015, 03:13 AM | #2 |
Re: 1930 rims
Why not just pickup a used rim and paint it to match, much easier. I have heard they can be replaced but its a pain..
03-01-2015, 06:49 AM | #3 | |
Re: 1930 rims
Yes you can. Typically one uses a salvage rim as a donor for the needed wire for those spokes. |
03-01-2015, 11:25 AM | #4 |
Re: 1930 rims
As In most things, it's the fit up that makes the difference. And the method of welding them in. Forget stick welding! So will it be gas, MIG or TIG? I would like TIG best myself. You're going to have two welds per wire. Your fit up needs to be tight to avoid any pulling of the rim. I think it would be easier just to buy a good rim.
Terry |
03-01-2015, 12:55 PM | #5 |
Re: 1930 rims
thanks
03-01-2015, 12:57 PM | #6 |
Re: 1930 rims
03-01-2015, 12:57 PM | #7 |
Re: 1930 rims
thankyou
03-01-2015, 12:58 PM | #8 |
Re: 1930 rims
hanks too all
