Old 11-05-2013, 08:10 PM   #1
Harylufa
Harylufa's Avatar
Default Vacuum test and Dwell...46´59AB
Hi!
Today I tested the vacuum and dwell with a timing light that I bought.
I attached a video about the test. I see that my engine is (setting the timing light) 8 cylinder and it is at 34º with 600 RPM. Is this correct?
https://www.youtube.com/watch?v=nON4Gjn1HZ4
I read that 36º at 600 RPM is the correct.
Vacuum gauge is marked at 18/20 in green range.
If there is something wrong please let me know.
Thank for reading.
Hary
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 11-06-2013, 08:49 AM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Vacuum test and Dwell...46´59AB
34 will work just fine...........
Vacuum is good as well..............
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-06-2013, 08:54 AM   #3
Harylufa
Harylufa's Avatar
Hi Bubba!
Thank for reading, Is better 36º?
Hary
Harylufa!
Old 11-06-2013, 09:38 AM   #4
Brendan
Brendan's Avatar
the vac is very good, nice and steady 20 in
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 11-06-2013, 06:13 PM   #5
BUBBAS IGNITION
36 is the spec but 34 isnt that far off. For every degree of dwell timing changes 2 degrees . So timing would be off 4 degree at the crank...
[email protected]
Old 11-06-2013, 08:02 PM   #6
Harylufa
Harylufa's Avatar
Bubba!
ok, must I retard or advance in the distributor to complete the 36º?
Thank for helping us.
Hary
Harylufa!
Old 11-06-2013, 10:15 PM   #7
Old Henry
Old Henry's Avatar
Changing timing doesn't change dwell. Changing dwell changes timing. Dwell is changed by adjusting the gap of the points in the distributor. Not an easy task on these distributors. I would say you are as close as you're going to get without a distributor machine to put the distributor on after removing it to get the dwell any closer. You are way close enough. Two more degrees would not make any noticeable difference in operation or performance of your engine in my opinion and experience.
Old 11-06-2013, 10:17 PM   #8
Old Henry
Old Henry's Avatar
One more thing. As a practical matter I believe timing is best set with a vacuum gauge to maximize vacuum at idle rather than trying to get it right on geometrically. And, best initial timing can be very different at varied altitudes. At 5,000 feet where I live I have to advance my timing all the way to maximize vacuum and get maximum power and performance out of my engine.
Old 11-06-2013, 10:28 PM   #9
40cpe
40cpe's Avatar
If my reasoning is correct, a slightly wide point gap will produce the lesser dwell reading. If so, the normal wearing of the points' rubbing block could gradually bring the dwell into spec. I would leave them alone.
40cpe is offline   Reply With Quote
Old 11-06-2013, 10:33 PM   #10
40cpe
40cpe's Avatar
Depending on the distributor curve, the best idle timing might or might not be the optimum cruise timing. I wonder if any testing has been done to establish cruise RPM timing with the vacuum gauge?
Old 11-07-2013, 12:43 AM   #11
Old Henry
Old Henry's Avatar
The point gap, which corresponds to the dwell angle, can be from 0.014 to 0.016 inches. That's a 12% leeway. Applying that to your dwell angle of 34° gives a leeway in dwell angle of 4°. So, you're well within that range.
Old 11-07-2013, 09:45 AM   #12
Harylufa
Harylufa's Avatar
Old Henry!
If you saw the video, you can see dwell is 34º and as you say it is very close to 36º.
I understand this:
"Changing timing doesn't change dwell. Changing dwell changes timing. Dwell is changed by adjusting the gap of the points in the distributor"
Now, if I advance/retard the dist, what for? which the effect in engine?
My engine is running good now after 17 year. And its interesting to hear engine sound being now in timing.
Thank for helping me
Harry
Harylufa!
Old 11-07-2013, 09:48 AM   #13
Harylufa
Harylufa's Avatar
Old Henry!
Where I live we are at sea level, perhaps I do not need advance the distributor. Am I right?
thanks
Harylufa!
Old 11-07-2013, 10:21 AM   #14
Old Henry
Old Henry's Avatar
Originally Posted by Harylufa View Post
Old Henry!
Harry
Change of timing changes efficiency and power of engine but only in a small amount not very noticeable.
Old Henry!
thanks
You are probably right about that. You could try it and see what happens to your vacuum gauge just to see if it improves any.
