05-03-2013, 10:58 AM | #1 |
Starter 1938...question!
Hi all!
Can anybody if this starter work in my Ford 1946? It is from a Ford 1938. If not, which is the difference between one and the other. I appreciate your help. Hary.
I love my Ford V8 1946! Harylufa! |
05-03-2013, 11:03 AM | #2 |
Re: Starter 1938...question!
No reason I can think of that it won't fit and function. There were some variations throughout the flathead era, so if being exactly correct for the year is not high on your priority list and worried about funtioning properly you should be fine. Rod
05-03-2013, 11:08 AM | #3 |
Hi Rowdy!
You mean that I can get it and it would work without problem?? Thanks Hary
05-03-2013, 11:46 AM | #4 |
It'll go right on. All 221-239-255 starters from 1932-53 EXCEPT automatic transmission cars will interchange. The one you show was used '32-48. I suspect it will go right to work with nothing but a bit of cleaning...I've never had any actual problem with the things.
05-03-2013, 12:00 PM | #5 |
Hi Bruce!
I really appreciate your info, I have the opportunity of buy it, It is cheap here. thank you Hary
05-03-2013, 03:48 PM | #6 |
05-03-2013, 04:52 PM | #7 |
it will work if the starter is good....so test before installing....Mike
05-05-2013, 05:18 PM | #8 |
Hi all!
Ok, I need it as spare part, so I will buy it. Thanks for posting Hary
