Old 07-05-2023, 08:45 PM   #1
sandbug
Default 1930 Ford Model A, Acceleration Noise
It’s a 1930 Model A Deluxe Roadster.
It has a ‘32 B engine in it, 12 volts, FSI ignition, Webber carburetor, 4-into-1 Header, Red’s Smithy's Muffler.
When I accelerate under load, it makes a loud banging noise in the engine compartment. This happens especially under full throttle. If I let off the acceleration, it stops, but as soon as I put it on full throttle under load, like on a hill, it makes the banging noise. Please listen and watch my video, and let me know what it is. Thank you very much as this has been going on for years now.
Note, it doesn’t seem to affect the acceleration. It’s just a noise.
https://youtu.be/-iehc7PbtqY
sandbug is offline   Reply With Quote
Old 07-05-2023, 09:46 PM   #2
Dino's A
Dino's A's Avatar
Default Re: 1930 Ford Model A, Acceleration Noise
I'm thinking either transmission or U joint.
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 07-06-2023, 12:08 AM   #3
AzBob
Kind of hard to tell in the video but sort of sounds like pre-ignition to me. You say it has FSI ignition. Have you checked the timing? If not that then something is loose.
AzBob is offline   Reply With Quote
Old 07-06-2023, 08:18 AM   #4
Planojc
Planojc's Avatar
Had a rattle like that and it was the starter bendix rubbing against the flywheel.
Planojc is offline   Reply With Quote
Old 07-06-2023, 09:02 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
The noise has the aspect of an ignition problem, too much spark advance.
Bob Bidonde
Old 07-06-2023, 10:50 AM   #6
Tom Endy
Tom Endy's Avatar
Also check that the three starter mounting bolts are the correct length, if they are too long, they can rub the flywheel. 3/8-16 X1"
Tom Endy
Tom Endy is offline   Reply With Quote
Old 07-06-2023, 10:55 AM   #7
Richard Knight
Classic pre ignition. Too much advance
Richard Knight is offline   Reply With Quote
Old 07-06-2023, 11:44 AM   #8
Big hammer
Pre ignition……. STOP driving until you find and fix… could be timing issues ( that’s what is nice about original, just retard the timing with the hand lever), could be wrong/to hot of spark plugs, could be a hot spot in the combustion chamber such as carbon buildup, could be a very lean fuel mixture. Remove the spark plugs and check them would be the first thing that I would do, search the Internet for reading spark plugs, too much information to post here.
get a bigger hammer tap done
Old 07-06-2023, 12:03 PM   #9
tinkirk
tinkirk's Avatar
Sounds like mine under load when not warmed up yet
Hasn’t hurt anything yet, had it all apart this past winter and found nothing out of the ordinary, put it back together and it still makes the noise
Beginning to wonder if it’s moisture related, bottom of intake has a lot moisture dripping off the bottom
Seems to go away once it’s up to temperature
Terry
tinkirk is offline   Reply With Quote
