05-11-2018, 05:37 PM | #1 |
Model A hood sizes Question
Are 28/29 Model A hoods the same size in Coupes as in Sedans???
05-11-2018, 05:40 PM | #2 |
Re: Model A hood sizes Question
yes unless briggs body sedan ,
05-11-2018, 05:50 PM | #3 |
Ok thanks! Briggs would be a taller hood then?
05-11-2018, 09:25 PM | #4 |
Both 1928-29 Briggs and Murray fordors hoods have a embossed body line (like 1930-31 cars) that other models those years don't have. I'm guessing they are the same size. Length height and width.
05-12-2018, 08:56 AM | #5 |
so that is some conflicting info i got from you guys... anyone else certain?
05-12-2018, 09:53 AM | #6 |
Bob |
05-12-2018, 05:36 PM | #7 |
Briggs and Murray cabriolets and fordors used one style hood in 1928/29 all other body/trucks styles use the more common hood. While the front part is the same on all bodies for those years, the rear part is different where it fits around the cowl. The cowl is higher/wider on cars with gas tank under the cover. Not the same as 1930/31 that was used on ALL Fords.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 05-14-2018 at 08:57 AM. |
05-13-2018, 12:11 AM | #8 |
Page 13-2 2016 edition of the Restoration guidelines
HOOD PANELS 1928-1929 Ford-produced bodies used smooth hood top panels, whereas the Briggs and Murray bodies (except Taxis) used top panels with a stamped moulding feature, similar to 1930-1931 hoods. Both styles of 1928-1929 hoods utilized the same side panels (See illustrations for louver changes) The hood side panels had a rolled reinforced edge at the base. The first design had the edge of the rolled metal exposed on the outside of the hood. The panels produced after July 1928 had the metal folded outward and rolled under (inward). All 1930- 1931 hoods had a stamped moulding feature in the top panel and the side panels had the louvers on a raised panel area. There were two varieties of the forward edge of the stamped moulding feature. Both sides must match. All hood sides were curved top to bottom including the louvers. The curve was slight at the front and increased towards the rear, matching the curvature of the cowl. (Lack of this curve feature is especially noticeable on nonauthentic 1930-1931 hoods.)
05-13-2018, 10:02 PM | #9 |
Very good info... Thanks!
05-13-2018, 11:46 PM | #10 |
29 cabriolets also use the fordor hood and they ,along with the fordors are the only body styles on which cowl lights are can be used
05-14-2018, 01:30 AM | #11 | |
Cowl lamps were introduced in 1929 and had an acorn shape similar to 1928-1929 head lamps. They were standard features on 1929 Cabriolets, Town Sedans and Town Cars. The lamp shells and arms were bright nickel plated, except during the period from October through December 1929, when they were either nickel or chrome plated to match the head lamps. With the introduction of the 1930 models, the cowl lamps had a shape similar to 1930-1931 head lamps and were stainless steel with chrome plated arms. They were standard equipment on deluxe body types and offered as accessories on other models. Early 1930 cowl lamps were assembled with a 10-32 oval head nickel plated screw through the rear of the shell.
05-14-2018, 11:16 AM | #12 |
The March 1929 Service Bulletins ,page 329, states "Cowl lamps used as standard equipment on the Town Car are now available through service for installation on all other types of Ford cars."
Bob |
