05-30-2018, 02:19 PM | #1 |
Beware
Know of a guy who tried to install a new Brassworks rad. Only problem is lower outlet way too small, hose way too loose. Beware
05-30-2018, 02:30 PM | #2 | |
Re: Beware
Charlie Stephens |
05-30-2018, 05:42 PM | #3 |
Re: Beware
Co says Ford's drawing had no size. Their suggestion was to wrap friction tape around lower outlet......................................
Paul in CT |
05-30-2018, 05:45 PM | #4 |
Re: Beware
that's BS and we all know it....
The vendors that make the hoses seems to know the correct size |
05-30-2018, 08:37 PM | #5 |
Re: Beware
yea even on brassworks website they claim the outlets they measured were 1 11/16 so they went with 1 5/8"? said if it fits loose wrap duct tape around the outlet then slip the hose on... Yea thats great quality...
Go with Bergs - pricey but have heard nothing bad about the radiators or the company. looks like brassworks went to China or Vietnam for labor or tooling or something. For what you pay for one it should be a nearly drop in and go item with all the holes lined up.
05-31-2018, 06:11 AM | #6 |
Re: Beware
05-31-2018, 06:47 AM | #7 |
Re: Beware
Shame on them! Too blatant error...If, as they said, Ford drawing did NOT have size, They should have held up production until they had the specs. If they could not obtain they specs they should have corresponded with you and found out what size hose you would be using and where your purchased it.Then they could have designed to fitting to fit your hoses.
05-31-2018, 07:30 AM | #8 |
Re: Beware
My experience was different. I drove over to the shop, got a tour and picked up my radiator. All dimensions were right on and it does the job. I still recommend Brassworks.
05-31-2018, 07:49 AM | #9 |
Re: Beware
In Holland we have a shop installing new Brasswork core, reusing your original upper and lower tank
05-31-2018, 10:50 AM | #10 |
Re: Beware
Been running Brassworks radiators in both my As for 15 years and never had a leak problem. Or any problem with heating.
Only problem I had was my cars ran too cool! Had to add 160 deg thermostats. . . . Dick |
05-31-2018, 02:19 PM | #11 |
Re: Beware
I had a Brassworks on my coupe, the only problem I had was the mounting holes were never drilled so I had to drill them out. Made me wonder how that passed inspection but it is a nice cool running radiator. I should note, the hoses fit nicely.
05-31-2018, 03:13 PM | #12 |
Re: Beware
Just a ignorant question. Why if the lower pipe diameter is to small couldn’t you you a muffler tailpipe expander to increase the diameter or size of the pipe with out much difficulty. I use to do on other radiators when the size was off. I can’t see why it would be any different just because it was a model a radiator .
old car guy |
05-31-2018, 03:16 PM | #13 | |
Re: Beware
That's funny right there because evidently you don't know either!! . |
05-31-2018, 03:30 PM | #14 | |
Re: Beware
OK, this has been discussed on another forum already so some of this is redundant but the truth of the matter is there is way more to this than what some are giving credit for. First-off, this information is posted on their website, so a prospective buyer who is prudent will look at all the info FIRST before they place the order. FWIW, I have looked and I'm pretty sure the original print of the water connector is NOT at the archives. Maybe you can find it, but I have the same print as Lee does for the A-8005-B Assembly Drawing, ...and he is correct that the dimensions are not listed on that print. If you will take note, he explains that he has original tanks to use as samples and he knows what the correct size is supposed to be. His problem is he can build it correctly but the hose manufacturers don't. Now here is why this entire thread is SO asinine is that if someone really wants to have a the best experience, you send Brassworks your radiator shell AND you specify whether you are using the off-shore brand of reproduction hoses, the US-manufactured reproduction hoses, --or original Ford-made hoses. They can assemble your radiator that will give years of service where everything fits perfectly. If you don't want to spend the effort upfront, then do you really have the right to bitch, ….especially if the manufacturer is very upfront about these issues and prints them on their website for everyone to read??. . . |
05-31-2018, 04:33 PM | #15 |
Re: Beware
There is a slight problem to be dealt with here, sir, and that is that Vince Falter says the original hose size is 1 3/4
http://www.fordgarage.com/pages/Radi...nstruction.htm |
05-31-2018, 08:35 PM | #16 |
Re: Beware
The trouble with this & other 'bad part' rants is you only hear one side of the story.
06-01-2018, 12:13 AM | #17 |
Re: Beware
Amen!
06-01-2018, 12:30 AM | #18 |
Re: Beware
06-01-2018, 01:30 AM | #19 |
Re: Beware
I have never read about this problem with brassworks radiators in the past. What has changed I wonder?
06-01-2018, 10:41 AM | #20 | |
Re: Beware
I have to agree with your statement. I visited the Brassworks shop a year ago when we were in Cental California and that is how he explained it to me. He said bring in your radiator or send it to him and he will take measurements so it will fit your car. If you prefer, he can re-core your Radiator. David Serrano |
