Old 03-19-2023, 07:16 PM   #1
tetanus
Default oil canister what am I missing?
Seems I’m missing a bushing or something or I have wrong filter. It’s a motor craft fl-20. Way to much clearance. I tossed the old one now I am wondering if there was a reducer stuck on it. Oh it’s off a 46’ motor I am putting together
File Type: jpeg DBE443B1-5EE4-4E4A-87A0-2BEF51551E78.jpeg (55.0 KB, 29 views)
File Type: jpeg F6F608BC-A30E-45AC-A6B0-FEEDC978DCF7.jpeg (62.2 KB, 31 views)
tetanus is offline   Reply With Quote
Old 03-19-2023, 08:06 PM   #2
JayChicago
JayChicago's Avatar
Default Re: oil canister what am I missing?
Ironic that this post comes up now. See the discussion thread from yesterday titled "Oil Filter Canister Blues". His canister has a bushing thingy that he thought shouldn't be there, was trying to remove it.
Maybe different canisters take different filters with different diameter center holes.
JayChicago is offline   Reply With Quote
Old 03-19-2023, 08:11 PM   #3
19Fordy
19Fordy's Avatar
You need this filter. It fits the cannister. Other filters are ADVANCE AUTO #L20701, MOTORCRAFT FL-20, Hastings LF 101 and the one most folks on Fordbarn recommend WIX 51006.https://www.bing.com/search?q=purola...ANAB01&PC=HCTS
Old 03-19-2023, 09:54 PM   #4
tetanus
It is a fl-20
Old 03-19-2023, 10:01 PM   #5
51woodie
51woodie's Avatar
If you Google FL-20 filter, you will see that it comes with some gaskets and washer type seals. Maybe they were not in the box when you purchased the filter. I use Fram C4 or Wix 51006 in my '46 Coupe, and on one occasion, there was no gasket when I opened the box. I guess someone else needed one.
51woodie is offline   Reply With Quote
Old 03-19-2023, 10:12 PM   #6
tetanus
Yes I have those gaskets the 3 big ones for the lid, not sure why I got 3 ?? Looks like there different thicknesses. And I did get the 2 small ones also. Something is missing have to check solvent tank maybe the “Washers” are in there.
Old 03-20-2023, 07:57 AM   #7
flatford8
flatford8's Avatar
The filters I use have a bail on the top to pull it out when you’re changing it…. Yours isn’t upside down is it?…..my filter canister has a crown shaped washer in the bottom that keeps the filter up off the bottom of the canister…..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-20-2023, 12:20 PM   #8
Mart
Mart's Avatar
The filters normally have a grommet top and bottom that make it a reasonably tight (sliding) fit on the central column.
