Old 05-03-2022, 10:12 AM   #1
Pech33
Pech33's Avatar
Default Repairing a Heater Shut Off Valve
Does anyone have a source or know what you can replace the "composite" (?) washer with? It is just behind the metal washer.
Pech33 is offline   Reply With Quote
Old 05-03-2022, 11:34 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Repairing a Heater Shut Off Valve
I believe you can take (pry) the "micky mouse ears" off the rectangle that it is on, unscrew the shaft, replace the washer, re assemble and stake or solder the handle back on. Keep in mind where it seats needs to be true and not pitted from rust. That fiber washer seals the shaft when the valve is in the OPEN position. Otherwise it leaks there unless opened to the stop against the washer.
Old 05-03-2022, 11:40 AM   #3
Terry,OH
Terry,OH's Avatar
Try outdoor water faucet packing in the smallest diameter available.
Terry,OH is online now   Reply With Quote
Old 05-04-2022, 06:57 PM   #4
Pech33
Pech33's Avatar
Does anyone have a picture of the "inside" of these shut off valves? I talked with a gentleman today who says my brass washer does not belong on the threaded portion. It should only be a "packing material wound around the threads to form the seal." Of course it is special in that it has to accommodate temps at 212 degrees. We don't want to get our Flattys that hot, but in case you do, the normal packing is not for hot water and it will melt. I see some specialty websites have packing for steam valves that might work if they are small enough.
Any thoughts?
Old 02-14-2023, 09:13 PM   #5
tetanus
I am looking for the same seal for mine. Pech33 mine looks exactly like yours with the brass washer on it. the seal was just crumbs when I took it out.
tetanus is offline   Reply With Quote
Old 02-14-2023, 10:21 PM   #6
alanwoodieman
seals brass plug to brass/steel seat--mayby try to seal it using valve grinding compound
alanwoodieman is offline   Reply With Quote
Old 02-14-2023, 10:53 PM   #7
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-15-2023, 09:16 AM   #8
Kube
Kube's Avatar
Years ago, there was a person that made kits for these. I seem to recall in California. Perhaps someone with a better memory than me will weigh in...
Old 02-15-2023, 09:51 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
Get graphite string from plumbing department, wind some between nut and existing packing
Old 02-15-2023, 10:11 AM   #10
tetanus
i read on a old post on early v8 club some guy named Larry Caplan but where do i find him?
Old 02-15-2023, 10:24 AM   #11
Kens 36
Kens 36's Avatar
Try this: https://www.earlyfordv8.org/forum/vi...m=18&Topic=965
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 02-15-2023, 10:33 AM   #12
Kube
Kube's Avatar
that was the guy. Thanks for the memory "jog".
