Old 05-08-2021, 04:43 AM   #1
56yblock
56yblock's Avatar
Default iddle problem
hello everybody, i have a problem with my iddle,it stall after run fast or run in highway does anyone knows where the problem come from
56yblock is offline   Reply With Quote
Old 05-08-2021, 07:28 AM   #2
Daddio
Daddio's Avatar
Default Re: iddle problem
There's an adjustable anti-stall dash pot on the left side of the carb that slows the closing of the throttle linkage.
Daddio is offline   Reply With Quote
Old 05-08-2021, 07:29 AM   #3
Daddio
Daddio's Avatar
pic
Old 05-08-2021, 08:46 AM   #4
Dobie Gillis
Dobie Gillis's Avatar
The OP didn't say whether he has an automatic or a manual transmission. If he has a manual there is no dashpot.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 05-08-2021, 10:15 AM   #5
56yblock
56yblock's Avatar
it's for manual transmission and 2110 2 barrel carb
Old 05-08-2021, 04:58 PM   #6
KULTULZ
KULTULZ's Avatar
Post Re: iddle problem
It sounds to me that possibly your curb idle speed is not set high enough or the mixture trim is not balanced correctly/fault in carb/linkage.
Does it run OK around town?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 05-09-2021, 04:36 PM   #7
Daves55Sedan
Daves55Sedan's Avatar
Same thing happened to my Holley 2100 couple years ago and I assumed something wrong with carburator. Pulled carb off and put on one of my reserve rebuilt carbs (I've got 3 spare carbs always ready to install).
Took it out and ran it on highway again, but when I got into town, couldn't keep it going without manually throttling up in neutral.
Turns out, the crappy chinese made ignition condenser was faulty. Took it out and put an old used condenser in the distributor. Still using it trouble-free for all kinds of driving.
Old 05-09-2021, 04:39 PM   #8
Daves55Sedan
I also suggest keeping an eye on your fuel filter. Ethanol deposits are hard on these filters. I been having to replace filters once a year.
Old 05-09-2021, 05:28 PM   #9
KULTULZ
KULTULZ's Avatar
Thumbs up Re: iddle problem
... hmmph ...
Both good and important points.
Ethanol will eat a cellulose fuel filter.
Old 05-26-2021, 05:36 PM   #10
zuburg
zuburg's Avatar
I have a 1956 Thunderbird and do not have the dash pot. I determined that the original car was a manual, but when I bought it it was changed to an automatic. I haven’t yet got it on the road. I’m currently waiting for my brake booster to be rebuilt. I was told they could turn it around in a week, but 4 weeks later, still waiting.
Once I get it on the road, I’ll see if I have a stall problem.
zuburg is offline   Reply With Quote
Old 05-27-2021, 04:09 AM   #11
Tom in TN
Tom in TN's Avatar
Reason #3 to only use ethanol-free gas in our old vehicles.
Tom in TN is offline   Reply With Quote
