Old 01-02-2018, 02:51 PM   #1
Model A Fan
Model A Fan's Avatar
Default Diamond Block Questions
I have decided to exit the Model A hobby for the foreseeable future and will be parting with many of my extra pieces and whatnot. I have a diamond block engine that is numbered *A4870927* which brings the year of manufacture in right between 1938 and 1939.
What I'm hoping to find is more information about what their "deal" is. Given Model As were produced up until 1931, it is unusual for an engine to be produced so late. I understand that they may have been extra engines or that they were produced for non-auto uses. Does anyone have more information?
Also, what would be the value on one in good shape and in running condition? Mine has been painted a metallic blue, but is still operational. I don't think it would need a rebuild, but maybe just new gaskets. Thanks for the help.
I have included a link to the pics, they are the very last two photos on the album here:
https://www.jalopyjournal.com/forum/...or-sale.27941/
Model A Fan is offline   Reply With Quote
Old 01-02-2018, 06:22 PM   #2
TK in LA
TK in LA's Avatar
Default Re: Diamond Block Questions
A Fan, Here is a link that should help.
http://www.fordgarage.com/pages/diamondblock.htm
The later castings are desirable for the guys wanting to hop up a banger as the castings had better material and structure. The number on the block is probably not the number for the block itself but was transferred from the previous motor that was removed?
Hope this helps. I know others will chime in.
Good Luck
TK in LA is online now   Reply With Quote
Old 01-02-2018, 06:38 PM   #3
springerpete
springerpete's Avatar
If you look on the lower block, carb side just behind the timing gear case you should see a raised letter and two numbers. My diamond block reads C 5 7 which means March 5th, 1937. These blocks had some modern improvements in them. I am sure others will be able to tell you more
springerpete is offline   Reply With Quote
Old 01-02-2018, 08:56 PM   #4
Chris Haynes
Chris Haynes's Avatar
My Diamond block has X240.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-02-2018, 10:02 PM   #5
Synchro909
Synchro909's Avatar
My diamond A block has 1296 there. Anybody know what that means? I can't read the engine number on it but most likely it is of Canadian origin.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-03-2018, 12:41 AM   #6
Chris Haynes
It is my understanding that diamond block had no stamped number on the number boss.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-03-2018, 02:44 AM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
That number is not a diamond number.
Old 01-03-2018, 02:48 AM   #8
Chippy Minton
Aren’t you talking about a Model B block anyway? They would all have been produced after 1931. I would guess that many B blocks have had engine numbers stamped on them as required as, as stated, they did not come stamped.
Chippy Minton is offline   Reply With Quote
Old 01-03-2018, 05:18 AM   #9
juke joint johnny
juke joint johnny's Avatar
On Vince's site that would equate to December 9 1936 1296
juke joint johnny is offline   Reply With Quote
Old 01-03-2018, 05:52 AM   #10
jim1932
jim1932's Avatar
That is probably I296. Or September 29 1936
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 01-03-2018, 04:16 PM   #11
Synchro909
Synchro909's Avatar
Thanks, Jim and JJJ.
Consistent with comment above about these blocks not having numbers stamped on them, I can see that there is no star at either end of the number that is or rather, was there. I think it is probably a number put there some time since 1936 by who knows who and who knows why.
Old 01-03-2018, 05:13 PM   #12
TinCup
TinCup's Avatar
A "B" cam is one of the best parts of the these blocks but mostly that they were run in industrial motors such as combines and irrigation pumps which mean they ran at low rpm's and no lateral crank movement due to no clutch action most of the time. That way the original crank journals are usually in good shape. If the flywheel housing is still attached you will find another date stamp there.
TinCup is offline   Reply With Quote
Old 01-03-2018, 05:59 PM   #13
Chris Haynes
Model B had numbers on the bell housing, not the block. Model A Diamond blocks were available through the late '30's. Diamond blocks were not numbered.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-03-2018, 06:31 PM   #14
Chris Haynes
Default
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-03-2018, 08:39 PM   #15
Model A Fan
I am just as baffled by it as well, but I don't have a good photo currently. I will try to get a photo of the serial number before the new owner takes it away. It has stars on both ends of the number and based on one of the websites with the info, it is from between 1938 and 1939. I don't understand why someone would mark it with that number (coinciding to that time period) if it wasn't in fact made during between those years.
Hopefully a picture will provide some clues. I'll check on the block for a date code as well.
Thanks for the interesting discussion. I like that sort of thing.
Old 01-04-2018, 02:27 PM   #16
JRShaw
JRShaw's Avatar
Gentlemen - These discussions have peaked my curiosity about my own (rebuilt) diamond block engine earmarked for my roadster project. The letters are L226 preceded and followed by a slotted round head screw. Am I correct in assuming this lettering would indicate October 22nd of 1936?? Is it known that these diamond blocks came with a "B" cam?? Thank You in Advance.
JRShaw is offline   Reply With Quote
Old 01-05-2018, 03:23 AM   #17
Dollar Bill
Dollar Bill's Avatar
Isn't "L" the 12th letter meaning it would have been cast in December?
From my notes: Beginning in August 1932, complete Model A service block engines were all fitted at the Rouge with Model B camshafts and push rods (tappets), according to the Engine Production Foreman's records. This feature carried forward into diamond block production.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-05-2018, 04:16 AM   #18
Mike V. Florida
Mike V. Florida's Avatar
Here is some great information;
Old 01-05-2018, 03:12 PM   #19
Chris Haynes
Vince told me he has never seen a number like the X240 without the screw that is on my block.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-05-2018, 04:40 PM   #20
Synchro909
Synchro909's Avatar
After reading JRShaw's post (#16), I went back to my diamond A block and had a closer look. The number I gave in post #5 was incorrect. In better light, I can see it is J296 (not 1296) and just like JR's, it is preceded and followed by the shape of a screw head.
Following the reasoning expressed here, I figure that motor would have been cast on October 29th, 1936. Is that correct?
The block came to me as part of a deceased estate along with a couple of other disassembled motors, one being a B. The camshaft from the B block is easy to identify by the fuel pump lobe but how do I tell the B cam that was in the diamond A block from the ordinary A cams I also got?
