Old 07-15-2021, 07:29 PM   #1
Conaway2
Conaway2's Avatar
Default Muffler Tail Pipe Attachment
Has anyone come up with a different attachment for the tailpipe of an original style muffler ?
I’m worried that the original tailpipe clamp may be too rigid when the frame flexes and cause problems.
Modern tailpipe hangers are flexible, generally with a rubber part to allow some movement.
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 07-15-2021, 08:29 PM   #2
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Default Re: Muffler Tail Pipe Attachment
Brattons and Snyders sell the correct part. Be sure not to over tighten. The tail pipe needs room to expand when hot.
Ivan in southeast va. is offline   Reply With Quote
Old 07-15-2021, 09:39 PM   #3
McMimmcs
McMimmcs's Avatar
Thanks - Jim
It worked for 90 years so why waste your time worrying !
Old 07-15-2021, 11:38 PM   #4
Ruth
If the muffler/tail pipe are not bent correctly, and a lot are not, the stock clamp will not work as designed. I have an Aries muffler and it fits perfectly. I use their insulated clamp also.
Ruth
Old 07-16-2021, 04:05 AM   #5
1crosscut
1crosscut's Avatar
If your not worried about staying original there are plenty of the modern style tail pipe hangers with the rubber isolator that can be adapted for use.
I have one on my AA and it works extremely well.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-16-2021, 06:39 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Muffler & manifold connections that work properly:
Bob Bidonde
Old 07-16-2021, 06:45 AM   #7
nkaminar
nkaminar's Avatar
I have the Aries muffler/tail pipe and the stock clamp and it works well. No leaks and no squeaks. I used a floor jack to support the muffler when installing. I used the exhaust pipe cement as insurance but probably didn't need to. I wiggled the pipe to seat it correctly when tightening the clamp.
Old 07-16-2021, 07:03 AM   #8
jayvee34
jayvee34's Avatar
X2 except, did not use the cement.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 07-16-2021, 09:50 AM   #9
Ruth
Bob, I may be incorrect but I think the sleeve is upside down in your drawing? Small end should fit in pipe not manifold?
The way it is in your drawing the sleeve would just slip down the pipe. Nice drawings tho.
Ruth
Old 07-16-2021, 10:32 AM   #10
katy
katy's Avatar
I like to use socket head cap screws in this application:
Old 07-16-2021, 10:42 AM   #11
Ruth
I like using the No-Nut manifold clamp. Save from trying to get two wrenches in a tight place. https://www.snydersantiqueauto.com/P...earchByKeyword
Ruth
Old 07-16-2021, 10:52 AM   #12
AL in NY
AL in NY's Avatar
Here is a photo of a tail pipe hanger I made for my 30 CCPU. The tail pipe is at the same height as it would be with the original clamp.
AL in NY
AL in NY is offline   Reply With Quote
Old 07-16-2021, 11:49 AM   #13
Conaway2
Conaway2's Avatar
Thanks for all the comments.
I have an original style tailpipe clamp, but had to tighten it a couple of days ago to eliminate a major rattle. While the rattle is now gone, I worry about the tailpipe having enough freedom of movement when the car is moving.
Al in NY - I really like your solution.
Thanks to all - Jim
Old 07-16-2021, 11:59 AM   #14
jayvee34
jayvee34's Avatar
Great looking set-up. No worries with tail pipe rattling against the frame.
John
Old 07-16-2021, 01:29 PM   #15
Brad in Germany
Brad in Germany's Avatar
Thanks to all - Jim
To keep the original look, but eliminate the rattle at the tailpipe clamp, you can use one of these "Tail pipe clamp with insulation" sold by Brattons:
That stops the rattle between the clamp and the tailpipe but still allows the tailpipe to freely expand and contract with the heat.
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 07-16-2021, 01:51 PM   #16
Brad in Germany
Similar to that "no nut exhaust clamp", but if you are trying to preserve the original look, Early Ford Parts offers a no-bolt exhaust clamp where the "bolt" is attached to the clamp half and thus does not require a wrench to hold the bolts at the rear of the clamp to tighten:
These are especially helpful for use on right-hand-drive (RHD) Model A's where the various linkages, pedals, carburetor, etc, all block easy access to the exhaust clamp bolts.......but they also work well on left-hand-drive Model A's as well.
Brad in Maryland
Old 07-18-2021, 11:50 PM   #17
NZ28ModelA
NZ28ModelA's Avatar
Hi AL, did you find that you eliminate any engine vibration going through the chassis with this new bracket system??
I am looking at any solutions to decrease vibrations, and i know from modern cars, if you have anything on the engine touching the chassis directly, it will go through the body.. I presume having the exhaust hard mounted like that on the Model A will promote some vibration.
Steve in NZ..
NZ28ModelA is offline   Reply With Quote
Old 07-19-2021, 07:08 AM   #18
Bob Bidonde
Hi Ruth! I covered myself by indicating there are 2 sizes of sleeve due to variations in exhaust manifold IDs.
Bob Bidonde
Old 07-19-2021, 09:33 AM   #19
AL in NY
AL in NY's Avatar
Steve: that rubber insulated hanger definitely eliminates any tailpipe vibration from getting to the frame.
AL in NY
Old 07-20-2021, 07:08 PM   #20
NZ28ModelA
NZ28ModelA's Avatar
Hey AL, thanks!! Good to know!! I am always looking for ways to eliminate unnecessary vibrations.. And this looks like a cheap easy fix..
Steve
