06-23-2010, 12:21 PM | #1 |
Finally My Engine Is In
After what seems almost forever my engine is back in the car. The engine was a 276 cube full house flattie that was built in the fifties. I tried to reuse as much of the vintage speed stuff as practical. The pictures show a rough mockup and as installed in the car. I know it is a long post, I hope you guys understand.
Block: 59 bored .145, full traditional hot rod relief, numbers on bell housing match the frame numbers. Crank: Mercury 4 inch stroke ground .020 Rods: NOS French Pistons: EGGE 3 ring aluminum Rings: Hastings Valves: Manley 1.5 stainless steel Valve Springs: Isky Lifters: Original Johnson reground by H&H Flatheads Cam: Potvin Super 3/4 Heads: New repop Edelbrock Block Letter Intake: Vintage Edelbrock Block Letter "REGULAR" Hi-rise Carbs: Stromberg 97s rebuilt by Ford Barner Uncle Max Musgrove Linkage: Vintage with Ball Bearing end fittings Distributor: Stock by Ford Barner Ken CT Isador Water Pumps: Speedway |
06-23-2010, 12:57 PM | #2 |
Re: Finally My Engine Is In
Congratulations. You're on your way. Keep us posted.
06-23-2010, 01:02 PM | #3 |
Lookin' good, I know what that feels like
06-23-2010, 05:10 PM | #4 |
engine looks great...."numbers on bell housing the frame numbers"??...numbers on the transmission bellhousing?....original trans then....cool, hope it runs great and you enjoying driving the heck out of it...Mike
06-23-2010, 06:25 PM | #5 |
Very Nice!!!
06-23-2010, 07:25 PM | #6 |
Vergil
Bigger fonts to aid in reading |
06-23-2010, 09:38 PM | #7 |
I am uncle max and I approve of this post .
06-23-2010, 09:59 PM | #8 |
Very nice. And the build list looks impressive.
06-24-2010, 09:25 AM | #9 |
The numbers are located on the bell housing part of the block not on the transmission. I don't know if it was a Mercury thing. thanks for your comments, larry
06-27-2010, 09:41 PM | #10 |
Laryh,engine looks great, your eng. lift mount bolted to top of eng .looks to be strong and safe I like it. Harold, central coast Ca.
06-29-2010, 08:45 PM | #11 |
Thanks for the comment. I made the lift out of 3/16 steel plate. I wanted to make it in one piece but didn't have enough metal. I cut the plate with a 4 1/2 inch grinder using a cut off wheel.
