05-24-2020, 07:22 PM | #1 |
1928 Open car door latches
Guys,
This should be a no brainer and an easy disassembly... On the back side pf the 1928 inside door latches for Open Cab, Roadster and Phaeton is a rectangular "gaurd" that covers the working parts of the latch. I have removed the split rivet on the front side of the latch thinking that it would then come off...wrong. Have used a punch to drive down the cover...will not budge. It should just come apart but it does not. What am I not doing to get this off so I can get the handles plated? Thanks. Pluck |
05-24-2020, 08:14 PM | #2 |
Re: 1928 Open car door latches
You should ask oldbluoval - he rebuilt mine and he knows latches very well.
"The more things change, the more they stay the same." |
05-28-2020, 12:29 AM | #3 |
There are some little tabs that come through the back plade. You may need t make sure they have not been taped over so they do not let go. I ground mine back with a light grind and then taped tem out. be careful as there are two strong springs inside when it comes apart. good luck.
05-28-2020, 07:38 AM | #4 |
Got them off but was a challange...had to drill out the large single tab.
Pluck |
05-28-2020, 07:57 AM | #5 |
05-28-2020, 08:25 AM | #6 |
Wanted flathead speed equipment Thanks |
05-28-2020, 10:05 AM | #7 |
05-28-2020, 07:01 PM | #8 |
Steve be careful that rivet that holds the handle is a stepped rivet. You should be able to get one from the suppliers over there. I had to make them for my car. I used a square shaft flat head screwdriver held in a vice to help push against the latch while seating the cover back in place.
Good luck. |
05-28-2020, 07:40 PM | #9 |
Tim let me check how many I have left from my run on them. How many do you need left or right . We made them out of O-1 and RC of 50 and exactly like originals. It’s very handy to have a machine shop
05-28-2020, 07:41 PM | #10 |
Wow, great. Just one left and one right. One of mine is a tad worn.
05-28-2020, 09:44 PM | #11 | |
How many do you have Hop Up? Thanks. Pluck |
