12-02-2017, 11:36 AM | #1 |
Columbia Two Speed 37-41 Info Please
Hi,
I'm missing the two springs that go on either side of my 37-41 Columbia Two Speed speedometer transmission spring arm. The part numbers are #B-35: B-35 ______63589 ........96H17297. ... 2 ..........Adapter Lever Tension Spring I've measured the shaft and figure the springs need to be 3/16" inside diameter and about 9/16" long. I expect the spring wire is pretty light weight. Can someone provide a close up picture and or some dimensions? Thanks |
04-19-2018, 09:55 AM | #2 |
Re: Columbia Two Speed 37-41 Info Please
here you go
04-19-2018, 12:08 PM | #3 |
Thanks, Glenn Note that there are two "B-35" springs. One above the thin spring steel arm and one below. The spring below is compressed in gerheadbill's photos so not evident. Just adding this in case someone is looking at this in the future for help. Last edited by glennpm; 04-20-2018 at 07:36 AM. Reason: For benefit of future queries |
Thread Tools | |
Display Modes | |
