05-15-2010, 06:17 PM | #1 |
Vent window rivets?
Does anyone know any vendors who sell the front door vent window rivets? I need to refinish my window frames and install new vent window seals on my 48 Merc coupe. I have not been able to find a vendor who sells them. My local glass installers are no help at all.
05-15-2010, 07:04 PM | #2 |
Re: Vent window rivets?
The Vintique vent window seals sold by Macs include the rivets, but they're not pop rivets. I guess you need special equipment to install them. I've disassembled one side only until I get around to doing the woodgrain on the escutcheon, I'm leaving the other side alone for now. My original rubber isn't that bad, I just need to refinish the woodgrain. I have also heard that Vintique rubber isn't that great, debating buying the Dennis Carpenter set if I'm going to go through all the work.
05-15-2010, 07:11 PM | #3 |
Unless you are in Concours judging you can use small (10-32?) machine bolts and nuts. That's what I used and the judges didn't catch it. John
05-15-2010, 07:47 PM | #4 |
There a vendors that have a small bolt with a rounded head that looks like a rivet. They are used to mount the handles and latches on trunks for Model A's and other cars, also used on tool boxes. Basically, bolt and nut as oldford2 described with out any standard slot or phillips slot in the head.
05-15-2010, 11:38 PM | #5 |
If this is the rivet that holds the frame of the window to the vent frame, I used a stainless machine screw with a nylock nut. My car is a street rod though. |
