Old 07-19-2014, 07:38 PM   #1
L-head
Default 40 Ford brake
39-40 Ford brakes are considered "Lockheed." Does the short lined shoe go to the front or does the long lined shoe go to the front of the backing plate?
L-head is offline   Reply With Quote
Old 07-19-2014, 07:50 PM   #2
40cpe
40cpe's Avatar
Default Re: 40 Ford brake
The long shoe goes to the front. It can be remembered by the larger side of the wheel cylinder pushes the long shoe.
40cpe is offline   Reply With Quote
Old 07-19-2014, 08:02 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
40cpe's answer is CORRECT! Just make sure you read his answer CAREFULLY since you asked your question about "short" shoe. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-19-2014, 11:11 PM   #4
avrotom
I brought my drums and shoes to an industrial frictions(brake and clutch) rebuild shop and they put long linings on all my shoes, and arced them nicely to fit the drums. What is going to be the result of using them like that on my stock '40, good, bad, noticeable?
avrotom is offline   Reply With Quote
Old 07-19-2014, 11:51 PM   #5
Lanny
Lanny's Avatar
I bet that Now, you should be able to stop on a dime,
and get a nickel back in change....
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 07-20-2014, 02:38 AM   #6
Mart
Mart's Avatar
I don't know if having long shoes all round would cause a major problem, but it wouldn't be difficult to cut the linings on the rear shoes shorter. If riveted, just cut through the lining and drill out the rivets.
Mart.
Old 07-21-2014, 07:51 AM   #7
jkeesey
jkeesey's Avatar
A lot of the shoe replacements are now coming all long shoe. On the dozen or so that Ive installed I haven't been able to tell a seat of your pants difference in braking.
jkeesey is offline   Reply With Quote
Old 07-21-2014, 01:10 PM   #8
supereal
supereal's Avatar
Long (primary) shoe faces to the front of the car. The idea was to place most of the braking force on the anchor, instead of the wheel cylinder, in Lockheed brakes, That ended when the style was hanged to the floating brakes of '49 and later.
supereal is offline   Reply With Quote
Old 07-22-2014, 12:10 AM   #9
avrotom
Thanks guys, I think I will leave the shoes as they are and see how it likes all "long" shoes
Tom
