Old 08-16-2010, 01:01 PM   #1
Mitch
Default Head gasket for Brumfield head
I have ordered and am going to use Felpro 7013 head gasket as recommended. I would like to know what the reasons are for not using the head gasket from Snyders that they call "modern" (steel with composite and silicon). Does anyone know?
Mitch is offline   Reply With Quote
Old 08-16-2010, 02:35 PM   #2
Larry Brumfield
Default Re: Head gasket for Brumfield head
Yes, I know. But I don't feel like typing three pages to explain it. If you use Snyder's gasket on a Brumfield Head it will likely burn out.
Thank you for following the manufacturer's recommendation instead of some opinion on a message board.
Larry Brumfield is offline   Reply With Quote
Old 08-16-2010, 02:46 PM   #3
MikeK
MikeK's Avatar
Larry has posted many times that he is not satisfied with the 'fit' of other gaskets to the head. Personally, I have seen too many blown out silicone ringed composition gaskets and would not go that route even if they fit. I don't know why the vendors call that silicone gasket "modern", new cars don't use any types of gaskets that require retorquing.
Here's somebody that I wish made "A" gaskets in their MLS line. They do have them for flatty 8's:
http://www.cometic.com/est.aspx
MikeK is offline   Reply With Quote
Old 08-16-2010, 05:51 PM   #4
tuneman
tuneman's Avatar
Yes mitch
I to have first hand knowldge of blowing out the silicon head gaskets on my brumfield head! I also have first hand exp on blowing out
a couple of felpro gaskets. Because i did'nt
follow LARRYS ADVICE and torque to 65 pounds and do it just as his directions said!!!
Follow his directions to a T. then retorque till
they stay at 65 pounds now matter how many times it takes to hold 65!!! I have had NO PROBLEMS SINCE DOING THIS. Made a beliver out of me!
tim
tuneman is offline   Reply With Quote
Old 08-16-2010, 06:15 PM   #5
Larry Brumfield
Actually, my re-torque instructions (back off 1/8 turn) apply to ALL flat heads regardless of the make and in my opinion it is most important.
About 3 re-torques ought to be enough.
Old 08-16-2010, 08:23 PM   #6
Mitch
Thanks for the reassuring responses.
Old 09-02-2010, 03:25 PM   #7
Jason in TX
Jason in TX's Avatar
Wow. That cometic makes flathead gaskets, but they are $147 each! yowza!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
