Old 01-24-2021, 06:56 PM   #1
30-9
Default 51 f1
All stock.
Today when leaving the house (after 5 min idle warm up) it felt like the emergency brake was on. I pushed clutch in and checked and the brake was off. I then left for store. All good except....when pulling into parking spot in first gear, a huge rapid bang bang bang and stumbling vibration - felt like the tranny was gonna fall out the bottom. I pushed clutch in, truck idled fine. After getting my wits back (scared crap out of me) I Let clutch out and truck acted like nothing happened. Went into store, drove home all good.
Truck has new front motor mounts, under a year old. . Rears I haven’t changed yet.
Thoughts?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 01-24-2021, 07:37 PM   #2
3twinridges
3twinridges's Avatar
Default Re: 51 f1
That sounds terrible. If the sound you heard was made while you were turning into the parking spot, I wander if you have an issue in the rear axle, like a chipped tooth in the spider gears?
I am sure more knowledgeable mechanics will be along, but If you are pretty sure it’s in the driveline, I would drain the fluids looking for metal in the gear oil or bottom of both cases.
JB
3twinridges is offline   Reply With Quote
Old 01-24-2021, 08:49 PM   #3
fordf1trucknut
Default Re: 51 f1
I had something similar happen to me once in my f1. In my case it ended up beeing the pin in thr carrier that the spider gears are on sheared the roll pin, allowing it walk out a bit and smack the end of the pinion gear... did a bunch of damage.
23 t touring
25 tt huckster
30 coupe
30 coupe (traditional hotrod)
31 pickup
38 standard
42 gpw (ford army jeep)
48 f-1
52 f-1
52 f-1 4x4
55 chevy
55 m38a1
56 Victoria
68 bronco
70 land rover
72 club wagon
fordf1trucknut is offline   Reply With Quote
