02-04-2019, 11:19 AM | #21 |
Re: Battery in wrong
I want to thank everyone for their help. I called the seller and he said they didn't touch the battery and looking at a video they made the amp was charging so I'm leaving it negative ground.
02-04-2019, 11:38 AM | #22 |
Sounds good. If you are having issues with charging it, might be the charger or battery. You could take the battery to an auto parts store and have it tested.
I know the voices aren't real but damn they have some good ideas! |
02-04-2019, 12:26 PM | #23 |
Batteries can explode when hooked up wrong . If it is charging it should be good .
02-04-2019, 04:12 PM | #24 |
Best to do the electrical as original so the next person won't have a mess to deal with and have to figure it out. Mark the cables and posts with red and black so anyone could attach a charger W/O being injured. Your choice on what to use for ground only know that it was always pos. to ground. Bulbs, starter, don't care and generator if re-polarized dosen't care either.
02-04-2019, 06:01 PM | #25 |
Most all vehicles are now negative ground . Most people have never heard of positive ground so they just make a razoo and connect the cables wrong .
02-05-2019, 12:54 PM | #26 |
02-10-2019, 03:45 PM | #27 |
I have never seen a starter run backwards. Does that mean its sucks the varmits in thru the exhaust and pukes them out the carb? Just curious,,, i am old senile.
