Old 05-08-2010, 06:17 PM   #1
antiquepa
antiquepa's Avatar
Question pitman arm
Are thhere any dis-advantages of the shortned pitman arm.
antiquepa is offline   Reply With Quote
Old 05-08-2010, 06:55 PM   #2
Bruce,Upstate NY
Default Re: pitman arm
Not that I've found in the last 20 years uf using one.
Bruce,Upstate NY is offline   Reply With Quote
Old 05-08-2010, 09:02 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
If the pitman arm is 25% shorter, the steering wheel freeplay will be 25% greater, but this shouldn't be a problem with a well rebuilt steering box.
Old 05-08-2010, 11:30 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
I could be hiding worn out parts in the steering system. When I rebuilt my stock steering it felt like power steering compared with what it was before the rebuild and adjustments.
Old 05-09-2010, 07:24 AM   #5
Bruce,Upstate NY
Any more apparent free play would be from sloppy linkage rather than in the box itself
Old 05-09-2010, 09:34 AM   #6
JoeWay
JoeWay's Avatar
Very good point, Bruce. I had to stop and think for a moment, but you're right.
Any play due to conditions between the steering wheel and the pitman arm will be the same with a short or long arm. Play due to conditions beyond the arm will be perceived as greater with a short arm.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 05-09-2010, 09:49 AM   #7
Tom Wesenberg
Yes, thanks for mentioning that as you are correct. If there was any slop beyond the steering box, that would be amplifyed by the same percent that the pitman arm is shortened.
Old 05-09-2010, 12:10 PM   #8
John LaVoy
John LaVoy's Avatar
The short pitman arm requires a larger turning radius, this may not be important to everyone but you can't turn as sharp with the short pitman arm.
John LaVoy is offline   Reply With Quote
Old 05-09-2010, 02:51 PM   #9
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
As long as the steering box can take the wheels to full lock, there is no change in the minimum turn radius.
If you mean "for a given amount of steering wheel movement", your answer is correct.
If you mean "the minimum radius that the car will turn at full lock", then your answer is NOT correct.
A shortened pitman arm results in SLOWER slower steering, but needing less effort at the steering wheel, but there is no effect on turning radius.
Regards,
Bill Lee
BillLee/Chandler, TX is offline   Reply With Quote
