Old 12-28-2023, 06:23 AM   #1
johnbuckley
johnbuckley's Avatar
Default Transmission bearings .. sealed or unsealed?
Any consensus on longevity of input/main drive bearings ( A 7025 and 7065)? Sealed? Unsealed? One side sealed? If single seal whether best to have the seal on the trans (or as per Vince Falter) on the UJ side?
johnbuckley is offline   Reply With Quote
Old 12-28-2023, 10:59 AM   #2
katy
katy's Avatar
Default Re: Transmission bearings .. sealed or unsealed?
One seal, away from the lubricant
Old 12-28-2023, 01:39 PM   #3
Gene F
Gene F's Avatar
I have heard you can remove the seal on one side without hurting the unit, and causing the other side to leak. Any thoughts?
Gene F is offline   Reply With Quote
Old 12-28-2023, 01:45 PM   #4
katy
katy's Avatar
One can remove one of the seals and it will not affect the seal on the other side. Bearings are sold with 1 seal or 2 seals or no seals. They are also sold with or without shields which look like a seal but are not.
Old 12-28-2023, 02:24 PM   #5
johnbuckley
is there a recommended way of removing one of the seals to avoid co-lateral damage?
Old 12-28-2023, 02:42 PM   #6
Grier
Take a pocket knife and just pop it out by slipping the knife point under the inner diameter and pry it a little. It should just snap out. You won’t damage anything.
Grier is offline   Reply With Quote
Old 12-28-2023, 03:37 PM   #7
Ordsgt
Ordsgt's Avatar
Agree with the above comments but would advise to not get Chinese made bearings US bearings are more costly but better quality. No fun pulling a trans out to replace a faulty bearing
Ordsgt is online now   Reply With Quote
Old 12-28-2023, 07:20 PM   #8
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
If you can find,locate&source these following brands: BCA, FAFNIR, FEDERAL, HYATT, L&S ,
Use a dental pick/scribe or " o ring" pick or flat blade screw driver to remove the seal.
Oldcarbearings is offline   Reply With Quote
Old 12-28-2023, 07:22 PM   #9
Oldcarbearings
The open side is always fitted/installed so as that's lubricated by the transmission/engine oil,
The sealed/sheilded side is to prevent foreign matter/objects entering through the bearing into the transmission.
Old 12-29-2023, 12:39 AM   #10
cristeven
I’ve not heard “long term results” but I’d suggest following the article below if you have questions during your rebuild. Tom’s work truly enables this work for many.
https://www.santaanitaas.org/wp-cont...ugust-2018.pdf
cristeven is offline   Reply With Quote
Old 12-29-2023, 01:21 AM   #11
Hitman
Most don’t drive their cars often enough to make a difference in the country of origin.
I’ve also had great success with Chinese bearings, but they’ve always been properly greased and torqued.
Hitman is offline   Reply With Quote
Old 12-29-2023, 01:42 AM   #12
updraught
updraught's Avatar
Lack of lubrication can be a thing with Chinese sealed bearings.
updraught is offline   Reply With Quote
Old 12-29-2023, 09:03 AM   #13
Benson
Benson's Avatar
Default Re: Transmission bearings .. sealed or unsealed? Do you also have the BAFFLES
already covered
Benson is offline   Reply With Quote
