Old 09-23-2023, 12:32 PM   #1
[email protected]
k_dodd@swbell.net's Avatar
Default Zenith Carb: New vs. Rebuilt
For a spare carburetor for my cars --is there an advantage or disadvantage of NEW vs REBUILT Zenith carburetors? I know that some reproduction parts are more problematic than others.
Kevin
Essex, CT
k_dodd@swbell.net is offline   Reply With Quote
Old 09-23-2023, 01:10 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Zenith Carb: New vs. Rebuilt
I personally would choose a rebuilt with good flow tested jets and proper cleaning and set up over new!
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 09-24-2023, 08:59 AM   #3
old31
Go with a good rebuilt, or rebuild one yourself.
Old 09-24-2023, 09:27 AM   #4
ampico-kid
I purchased a new Zenith Carb. about a year ago thinking I'd avoid potential problems with a rebuilt. I had purchased a new Zenith about 15 years ago and it was great, and I'm still using it today. With a "new" car now in the picture, and a problematic carburetor, I figured I'd bite the bullet and go for another new Zenith. I paid over $500 for it. It was nothing but grief and trouble. I ended up returning it for a full refund and picked up a nice Marvel Schebler that works great.
ampico-kid is offline   Reply With Quote
Old 09-25-2023, 02:18 PM   #5
Jeff/Illinois
Jeff/Illinois's Avatar
There are too many good original Zeniths 'floating around' sorry for the pun.
I'd go that route and avoid the 'new' ones.
An original with Renner's flo-tested jets and you can't go wrong.
Jeff/Illinois is offline   Reply With Quote
Old 11-01-2023, 08:42 PM   #6
SteveB31
SteveB31's Avatar
We rebuild hundreds of Zeniths every year and they work great. For fun, I bought a new Zenith last week to give it a try to see how they work. I could write for twenty minutes and not say all the things wrong with it. It ran. It didn’t run well. So many things to fix. Got it fixed and all good now. Don’t waste your money on the new ones.
SteveB31 is offline   Reply With Quote
Old 11-01-2023, 10:38 PM   #7
The Master Cylinder
The Master Cylinder's Avatar
As others have said, go with a good rebuild. I made the mistake of buying a new air balanced one. What a piece... For starters the throttle shaft had way too much clearance. It went doenhill from there.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-01-2023, 11:23 PM   #8
Brentwood Bob
And the rebuilds are broke in.
Brentwood Bob is offline   Reply With Quote
Old 11-02-2023, 06:37 AM   #9
marty in Ohio
marty in Ohio's Avatar
Oh, I don't know, guys. The day I received my very first Social Security check my wife and I drove to Snyder's and I bought a new Zenith. That's been 12 years ago and I haven't had a bit of trouble since.
Marty
marty in Ohio is offline   Reply With Quote
Old 11-02-2023, 06:43 AM   #10
Oldbluoval
Oldbluoval's Avatar
Reading thru the thread…..
Seems new carbs 12-15 years ago were good…now they are problematic.
Wonder what morphed between then and now? Outsourcing? Huuuum..same story as everything these days?
Oldbluoval is offline   Reply With Quote
Old 11-02-2023, 06:56 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bill, the biggest thing from those 12 years ago was they were each tested and flogged before they were sent to a customer.
Realistically, you don't need a spare carburetor for your cars if each of them have a correctly functioning carburetors already on them. Spend the time to have them correctly restored from someone like Steve, Gary, et/al that can fully renew the carburetor by installing a correctly fitted throttle shaft, flowing the jets, cleaning all passages, burnishing the GAV seat, etc. where the functionality will provide 40k-50k miles of flawless service. If you find yourself needing to swap to using a spare to clean the car's carburetor due to rust, water, etc., then my suggestion is to fix the root problem. Back in the day, Model-A owners did not need to own a spare carburetor.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-02-2023, 01:03 PM   #12
Brentwood Bob
Or call a tow truck.
Old 11-02-2023, 08:09 PM   #13
Gary WA
Gary WA's Avatar
I've had my carbs on my A's for twenty plus years and never have replaced them! Still running fine..
