05-09-2010, 01:13 PM | #1 |
Valve adj, touring cam
What's the gap setting for adj'able lifters, please. Thanx, FB
05-09-2010, 02:06 PM | #2 |
Re: Valve adj, touring cam
Same as regular lifters! .014 in and .016 ex I think. Check Les Andrews book any of the suppliers books.........
05-09-2010, 06:02 PM | #3 |
With new modern valves I set mine at .011, all. There is less growth in the new valves so you can set them closer.
05-09-2010, 06:43 PM | #4 |
BTW, where did you get the cam, --or even more importantly, who reground the cam? Depending on the specs, there may be a little Hp advantage running the exhaust valve a little loose however the noise may be a tad more than you want to hear.
05-10-2010, 12:09 AM | #5 |
