Old 03-08-2012, 10:32 PM   #1
'31 Patina
Default Anyone in St Paul or MPLS That Will Help?
I have a '31 coupe that I'm having issues with. I can't seem to get the idle adjusted properly or at least I think that's my issue??
After I've started the car and let it warm up, I go to put the throttle lever all the way up but the car will just die. I can drive the car but it idles high. I also can't get it into any gear after coming to a complete stop at a stop sign and I'm thinking it's because the car is idiling too high. If I try to put it into gear it just grinds so I end up sitting at a stop sign, for what seems like a long time, until I can get it into gear. Is this because the car is idling too high and the flywheel is turning to fast for me to put it into gear after coming to a stop? Or does this have something to do with timing?
I live in St Paul and if there's anybody in the area who would be willing to come by and give a young guy a hand/lesson that would be greatly appreciated. Send me a PM.
Thanks.
Josh
'31 Patina is offline   Reply With Quote
Old 03-08-2012, 10:56 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Anyone in St Paul or MPLS That Will Help?
Have you tried with the throttle lever all the way up adjusting the idle AT the carb??
Paul in CT
Old 03-09-2012, 05:48 PM   #3
jmeckel
jmeckel's Avatar
Here is link to a great document about rebuilding and adjusting a Model A Zenith carb. See page 16 for how to drive test and adjust the carb:
http://modelabasics.com/Carb/ZenithC...l2011-2007.pdf
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 03-09-2012, 09:33 PM   #4
Preacher
PM me for a LOT of help in the TC area.....
If it ain't broke, fix it 'til it is ...
http://tcmafc.org/
Preacher is offline   Reply With Quote
Old 03-09-2012, 10:05 PM   #5
real550A
real550A's Avatar
Be sure to check your intake manifold gaskets. A leak there will cause the engine to draw air, but no fuel. With the car running as low rpm as you can, wave an unlit propane torch around near where the intake manifold meets the block. If a leak, the
engine will speed up slightly.
Mike B.
Model A's and Porsches since 1957
real550A is offline   Reply With Quote
Thread Tools
Display Modes
