10-20-2011, 01:01 PM | #1 |
Clutch Pedal Arm Adjustment
I'm fairly new to my '31 coupe so I'll try my hardest to explain my question so people can understand what I'm asking.
When I start up the car and try to put it into 1st gear it grinds. When I come to a stop sign, and the car is at a complete stop, I try to put it into 1st gear and it grinds like crazy. I went to adjust the trunnion nut arm on the bottom of the clutch pedal but now I cant get the clutch arm to line up with the arm that comes out of the transmission so I can put the clevis pin back in. There is a little bit of play in the arm that comes out of the transmission, meaning I can turn the arm back and forth a little bit. Do I need to put a lot of pressure on this arm to get it so the clevis pin hole will line up with the clevis holes in the clutch arm pedal? I apologize if this doesn't make sense...it's hard to explain it on a forum. Thanks. |
10-20-2011, 01:18 PM | #2 |
Re: Clutch Pedal Arm Adjustment
Yes, you may need to put a bit of pressure on the arm to line up the holes. When I adjusted mine I used a small hydraulic jack under the arm.
10-20-2011, 01:46 PM | #3 |
Since you say you're fairly new to this game, I suggest you get a copy of the Ford Service Bulletins and Les Andrews Mechanic's Handbook Vol. 1. These two books alone will answer many of your questions, now and in the future.
10-20-2011, 01:55 PM | #4 | ||
The Les Andrews book Vol. 1 was one of the first things I bought and has been very helpful. I didn't find much on the clutch arm adjustment though. |
10-20-2011, 04:26 PM | #5 |
Yep to what Tim said.. Additionally, you want 1" to 1.5" of free-play[travel] in the clutch pedal.. You don't want to adjust the pedal so the release bearing is always contacting the fingers..
10-21-2011, 06:03 AM | #6 |
10-24-2011, 06:42 AM | #7 |
I adjusted my clutch pedal arm and the clutch no longer grinds when I shift into each gear while the car is parked and running. I still can't figure out why I can't get it into gear after I come to a complete stop at a stop sign.
When I get to a stop sign and I'm at a complete stop it takes anywhere from 15-30 seconds to get the car into first gear. I have the clutch all the way in and it grinds like crazy trying to get it into 1st gear or any gear for that matter. Once I get going it seems fine until I get to a stop sign or stop light. Any suggestions? I'm guessing I'll need to pull the transmission and see what's going on. |
10-24-2011, 07:36 AM | #8 |
Also remember to push the throttle lever back up after starting - a nice low idle speed will make shifting easier.
10-24-2011, 07:44 AM | #9 |
You haven't said what you're running for tranny fluid OR if you've changed it to proper weight (viscosity).
Paul in CT |
10-24-2011, 08:02 AM | #10 | |
I've changed the tranny fluid and I'm running 600W. I put my pinkie finger in the fill hole and the fluid level is at the tip of my finger. If I put any more in the fluid just ends up spilling out when I go to thread the cap back on. |
10-24-2011, 08:16 AM | #11 |
IF you've got the throttle lever half way down that's part of your problem, the tranny is NON-synchro. The engine speed at a stop HAS to come down so everything slows down and gears can be engaged w/out grinding after depressing clutch pedal. JMO Maybe someone else will explain it clearer.
Paul in CT |
10-24-2011, 08:32 AM | #12 | |
10-24-2011, 11:15 AM | #13 |
The throttle half way down is not only part of the shift problem (maybe all of it), but it's a dangerous way to drive. The throttle isn't really a cruise control and won't kick out when the brakes are hit. If you are out on a country road that's pretty flat and not much traffic, then you could use it for cruise, but I would leave the throttle lever full up once the engine starts and is warm enough to idle OK.
10-24-2011, 12:34 PM | #14 |
Are you putting the shift lever into neutral when stopped at a light and then trying to put the shift lever into gear once the light has changed ?? If so, thats a problem..
The throttle lever is the right side lever and if its left at about 1/2 travel [ 3:00] then the engine would be running at too high of an idle speed.. If so, thats also a problem.. Or, If what you're saying is that the shift lever just won't go from 2nd or 3rd directly into 1st and wants to hang up in neutral then the problem could be a badly worn shift lever ball.. |
10-24-2011, 01:00 PM | #15 |
pull the tower off, and look at the ball on the bottom of the shift lever. should be 1/2 inch round. Bob
10-24-2011, 03:39 PM | #16 |
One, the best way I have ever found to put that clevis pin back in is to use a pipe wrench on the front of the lever and rotate it till the holes line up. Second, you must adjust the free play to 1" at the pedal. More and it will grind less and it will slip. Mind you this 1" is subjective and a little latitude is necessary. If none of these adjustments work you may need a clutch, I hope this is not necessary but it could be.
