Old 05-01-2011, 04:03 PM   #1
'31 Patina
Default Fuel Shut Off Valve
I have a '31 coupe with the shut off valve in the cab under the gas tank. Gas slowly leaks from the jam nut on the handle.
Is it best to just buy a new valve or would it be worth trying the repair kit? The repair kit comes with packing, jam nut and lock washer. Is it possible that the valve I have needs new packing and that's why it's leaking?
Thanks!
'31 Patina is offline   Reply With Quote
Old 05-01-2011, 04:35 PM   #2
Ross/Kzoo
Ross/Kzoo's Avatar
Default Re: Fuel Shut Off Valve
I used the repair kit and it hasn't leaked in 4-5 years.
Ross/Kzoo is offline   Reply With Quote
Old 05-01-2011, 06:09 PM   #3
TK in LA
TK in LA's Avatar
Before tackling the packing on the valve be sure it isn't leaking down to the carb. You could spend a lot of time fixing a bad valve. A little tooth past is a good way to lap the valve before installing the packing, just to be on the safe side. My 2¢
TK in LA is offline   Reply With Quote
Old 05-01-2011, 06:14 PM   #4
'31 Patina
Is it difficult to repair the valve? It's not leaking down to the carb. It's only leaking around the jam nut on the handle.
Old 05-01-2011, 06:23 PM   #5
HARLEYJOE
HARLEYJOE's Avatar
I purchased new USA valve from Snyder's and installed it only to find out one of my gas lines inside had a small crack.
So not to play around I ordered new fuel lines and now happy and feel better that I did replace everything inside cab for I did not want to smell gas
inside cab.
I also felt the fuel lines were better designed and sealed better than the
ones that were there.
You surely do not want to have to drain that tank a lot to keep fixing
an interior leak..
HARLEYJOE is offline   Reply With Quote
Old 05-01-2011, 09:07 PM   #6
Fred K-OR
Fred K-OR's Avatar
I put in a new aftermarket valve on my 29 Huckster. But it leaked into the carb so thus the gas was not shut off. So I had to put another valve in between the one in the tank and the gas line. So it may be worth a try to repair the old.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
