08-26-2016, 04:40 PM | #1 |
Carb adjustment
Question for the experts/ My timing is dead on. Starts perfect. As soon as it starts I bring the advance all the way down. Idle goes up quite a bit.
Should I set idle after advancing? If so. should it stay running with advance retarded? |
08-26-2016, 04:55 PM | #2 |
Re: Carb adjustment
Yes to both questions
Coral Springs Florida |
08-26-2016, 05:28 PM | #3 |
Re: Carb adjustment
You shouldn't pull the lever all the way down...half at most....
Adjust your idle when retarded ...the cars like it looow... |
08-26-2016, 05:43 PM | #4 |
Re: Carb adjustment
If the spark lever travels from 10:00 to 8:00, most driving is just fine at 9:00.
These monster do not need 40º of advance, especially at low engine speeds. When the timing is right the engine will idle nice and slow with the lever up. The engine speed will pick up as the the lever is pulled down and still run smooth until it reaches 9-9:30. When the lever is fully advanced the engine will start to hunt a bit. |
08-26-2016, 07:23 PM | #5 | |
Re: Carb adjustment
08-26-2016, 10:18 PM | #6 |
Re: Carb adjustment
I like it low and smooth Sometimes you have to play with the idle fuel air mixture and gav to get it in the sweet spot On e there you can do a final adjust on you idle speed when retarded Where in Missouri are you ? Larry |
08-27-2016, 09:33 AM | #7 |
Re: Carb adjustment
Larry 40 Im in Springfield.
08-27-2016, 01:47 PM | #8 |
Re: Carb adjustment
08-27-2016, 06:16 PM | #9 |
Re: Carb adjustment
Read the post. I did not say it stops.
