08-11-2016, 04:43 AM | #61 |
Re: Got the old girl home
I bought a very rusty stuck engine once for $10 figuring I could save at least the rods and crankshaft. The pan was full of sand and rust, and the only thing I could save was a hand full of bolts.
08-31-2016, 11:55 AM | #62 |
There was very little sludge in the pan - not really worth taking a pic of :-)
Another question ... In the pan gasket set I received from a local guy, he takes the rope seal out of the set and gives a seal that has been soaking in oil [for several years]. The seal I received is quite "Firm". I have dealt with rope seal for other applications in the past and the rope was very rope-like and formable to the application. This rope is quite solid, even tho it has been soaking. It is preformed in a curve but I can't see how this solid piece of rope will easily form and compress to the surfaces it needs to. He assures me that this is the way they are supposed to be but I would like another opinion prior to assembly. I'm sure that I am overthinking things as I usually do .... Thanks, Frank |
08-31-2016, 12:11 PM | #63 |
60 years of working on all kinds of cars with rope seals, I have never soaked one. I also never had a rope seal leak. They were used for rear mains on a lot of cars. But it is your car do what you feel is best.
08-31-2016, 12:53 PM | #64 |
X2 what George said.
I also never soak them. It makes them an oily mess to install. I push the seal into place, then use a socket the same size as the pulley sleeve, and tap that into the seal to drive it home and shape it. I then squirt oil on the rope and smear it with grease. |
08-31-2016, 01:50 PM | #65 |
the rope seal can be put in boiling water just before placing it in the oil pan, then conformed with tom's method using a large socket.
08-31-2016, 09:10 PM | #66 |
08-31-2016, 09:16 PM | #67 | |
09-01-2016, 10:03 AM | #68 |
Thanks Tom, thats the second opinion I was looking for ... I will move foreword.
Frank |
09-29-2016, 08:50 PM | #69 |
So I got my Phaeton running the other day. Starting with the crank only - old, bad battery. Got some blisters til I got it's preferred settings figured out. Got it down to 1/4 turn now. Runs great, no smoke.
Question. I rebuilt the generator many years ago with a new cut out. How do I determine if it is operating correctly? I put power directly to the gen and it motors as it should. Should it motor when I put power to it through the cut out? It does. |
09-30-2016, 01:02 AM | #70 | |
09-30-2016, 02:31 AM | #71 |
The irons run under the front floor boards.
09-30-2016, 08:18 AM | #72 |
Very NICE phaeton Love it. I think it looks GREAT just like it is too but that's just me. LOTS of GREAT INFO here and help I've learned a lot just reading post. Good Luck and Keep On Truckin'!
09-30-2016, 09:28 AM | #73 |
Thanks Tom, as I said it does motor when I put power directly to the gen [to the stud]. I am wondering if it should motor when I put power [6v] to the cut out? I think not?
09-30-2016, 09:50 AM | #74 |
09-30-2016, 06:53 PM | #75 |
Thanks 40. There was continuity across the cut out so I removed the cover. It was a brand new unit many years ago with very little hours. There was a little dot of metal completing the circuit welded across the points. That is remedied and I will check the operation next time I have it running...
Thanks again, Frank |
10-01-2016, 12:01 AM | #76 |
I haven't seen a repro cutout that is quality and I could trust.
I always use restored originals. A quality diode cutout is also a good choice. |
10-01-2016, 12:28 AM | #77 |
This diode idea I've seen is intriguing. In theory the gen should be able to charge straight through a diode? Eliminating the cut out?
The cut out I have had very low hours. It is a Standard/Bluestreak unit - in the old days a quality aftermarket manufacturer, long before chinese junk. Last edited by 00fxd; 10-01-2016 at 11:54 PM. |
10-01-2016, 10:01 AM | #78 | |
You'll probably find more than you want to know on google.
10-01-2016, 11:41 PM | #79 |
Fantastic Phaeton! Great thread, look forward to the progress...
1928 Phaeton |
10-01-2016, 11:50 PM | #80 |
So those that are having problems with a points welded cut out could simply leave it as is and install a diode in line and have a more reliable system....
Thread Tools | |
Display Modes | |
