Old 10-25-2014, 08:39 AM   #1
Chris Marshall
Chris Marshall's Avatar
Default '32 rear quarter fender stud replacement
I recently acquired an original '32 roadster basket case. The body is very nice, but had some minor modification back in the day to be a "proper" hot rod. One of these was to grind off the 3 studs located at the back of the rear wheelwell. The heads are still there. My questions - what's the best way to replace those studs? Were the originals spot welded or swaged in place? What is the best source for the correct studs?
Thanks for the help!!
Chris Marshall is offline   Reply With Quote
Old 10-25-2014, 08:47 AM   #2
ReggieK
Default Re: '32 rear quarter fender stud replacement
I welded my studs in from the back side.
http://www.fordscript.com/ford_bolts/index.html
ReggieK is offline   Reply With Quote
Old 10-25-2014, 09:08 AM   #3
Andy
I would drill and tap the remains of the original studs. Screw in some all thread and weld the end to the old stud end. I would do in on the inside of the trunk.
Andy is offline   Reply With Quote
Old 10-25-2014, 11:14 AM   #4
deuce_roadster
deuce_roadster's Avatar
If the head of the stud is still on the inside, do as Andy suggests. I have fixed these many times like that, be sure to center the hole and drill from the inside. If you run a non cad plated bolt in from the back and cut it off with a zip wheel you will get a better and safer (no cad fumes) weld then if you use all thread which is usually plated.
Old 10-25-2014, 04:17 PM   #5
JSeery
JSeery's Avatar
If I was going this repair in the way Andy and deuce_roadster suggest, I would consider a stud in place of all-thread. Most all-thread is fairly weak and has sloppy threads as compared to a high quality stud.
Edit: Reread deuse_roadster comment, he was suggestion a bolt and not all-thread, which sounds better to me, so high quality stud or a bolt.
Old 10-27-2014, 07:16 AM   #6
Chris Marshall
Thanks for the replies. I'll try to drill/tap the original stud heads. While they have plenty of diameter, they seem pretty thin.
Old 10-27-2014, 02:12 PM   #7
BoxCar Tom
BoxCar Tom's Avatar
The studs as you call them are similar to carriage bolts with a thin head. There are three small spot welds, sheet metal to underside of the head to hold them in place. I think Roy has accurate replacements available. Installing replacements may be easier that drilling and tapping which may render marginal results.
Just checked Roy's catalog, see page 55
R-610-A Rear fender (wheelhouse) weld studs for 1932 (4 pcs/pkg) $ 4.50/pkg
BoxCar Tom is offline   Reply With Quote
