Old 02-15-2014, 05:35 PM   #1
1wonton
Default Head crack
My police head has a hairline crack across the top from the dist hole to the side down to the bottom. The head has no other cracks on the inside and is in otherwise good condition. What's the best way to repair it. I could probably leave it alone since it doesn't leak but I want to fix it right. Seems like a lot of work pinning it; whould brazing be the way to go here?
ron
1wonton is offline   Reply With Quote
Old 02-15-2014, 06:09 PM   #2
700rpm
700rpm's Avatar
Default Re: Head crack
Take it to a reputable engine machine shop and have them pin it. About $85 here in P-town.
Ray Horton, Portland, OR
Old 02-15-2014, 06:17 PM   #3
Ron W
Ron W's Avatar
Are you sure it's a crack and not a void in the casting? If it's not leaking, didn't look too bad,I would probably leave it. Ron W
Ron W is offline   Reply With Quote
Old 02-15-2014, 06:47 PM   #4
1wonton
I magnafluxed the top and it's definitely cracked. The crack is about 8" long; that's a lot of plugs and I don't think anyone is going to do it for $85. I can braze it and that seems like a good fix for cast iron. I just wanted to hear from anyone who may have encountered this problem before.
ron
Old 02-15-2014, 06:53 PM   #5
700rpm
700rpm's Avatar
Oh. It runs the long way. Yeah, $85 ain't gonna do it.
Old 02-15-2014, 06:58 PM   #6
Ron W
Ron W's Avatar
Wow! An 8 in crack that doesen't leak! In that case I might consider a new HC head. Ron W
