Old 02-15-2014, 10:57 AM   #1
grantsauder
grantsauder's Avatar
Default 1930 Rebuild Splash shield Bolts to Frame
I am restoring a 1930 Tudor which was never together in my time. Bratton's #22160 shows 4- 1/4-20 x3/4" step bolts to body running board splash shield to frame. Where are these bolts located ? I found two located at the rearmost holes in the shield. Where are the other two located? Hopefully the body will be installed on Tues.
Thank for your help.
Grant
grantsauder is offline   Reply With Quote
Old 02-15-2014, 03:31 PM   #2
Ken Ehrenhofer
Default Re: 1930 Rebuild Splash shield Bolts to Frame
Hi Grant
I believe you are referring to the two bolts that go thru the splash apron and thru the frame with frame welting between them. There is one bolt in each top corner of each apron. That will make for a total of 4 with both aprons,
The two holes in the rear are for attaching the rear fender,
Good Luck,
Ken
Ken Ehrenhofer is offline   Reply With Quote
