02-10-2014, 08:07 PM | #1 |
Pressurized Cooling System
I would appreciate hearing from those running a pressurized cooling system. Is coolant leakage at the water pump a problem?
What is the operating pressure? Do you have a coolant expansion and recovery contaioners?
Bob Bidonde |
02-10-2014, 09:13 PM | #2 |
Re: Pressurized Cooling System
I run a pressurized radiator. It's been this way for 3 or 4 years and never had a water pump leak problem. I run a 4 lb cap. Just enough to get it to and from the recovery bottle. I also have a modern VT fin core.
Cowtown A's |
02-10-2014, 09:25 PM | #3 |
I run a 4lb cap... No recovery tank.... Have had this setup
for 4yrs and 15K miles... |
02-10-2014, 09:36 PM | #4 |
You don't need a pressurized system to use a recovery bottle, but why do you want either?
02-10-2014, 11:53 PM | #5 |
