02-09-2014, 09:03 PM | #1 |
Distributer oiler.
Is the oiler press fit or threaded ? Tony
02-09-2014, 09:08 PM | #2 |
Re: Distributer oiler.
Press fit.
Stick a punch down inside the hole after pulling back the slide-cover. Twist the punch and the oiler will/should slip out of the housing. |
02-09-2014, 10:35 PM | #3 |
I put a punch in the oil hole as Brent said, then I use a flat blade screwdriver behind the punch to pry it out. This way there is no chance of deforming the oil hole.
02-09-2014, 11:56 PM | #4 |
Were all the oilers the same that were supplied from Ford? I have seen, and thought, that the 31 style had a flip door oiler instead of the pull out style oiler.
02-10-2014, 12:20 PM | #5 |
Brent and Tom are two really smart gentlemen!! thanks for always helping all of us.
02-10-2014, 04:32 PM | #6 |
